Results 1 to 5 of 5
Thread: Psu \ speakers buzzing(HELLP)
    Newbie nemz's Avatar
    Feb 2007
    heyz guys,,, been reading on this forum for a while, and finaly got around to building a carpc, only prob so far is that when the pc psu has power running thro it the speakers start buzzing, even if the pc it self is of and rcas are disconnected. im using standard atx powersupply and inverter,,
    does any 1 know how to fix the problem,?
    any help is much appreciated
    Nemz
    Constant Bitrate ivanmx6's Avatar
    Dec 2006
    Dorset, UK
    Where have you got the audio lines routed?
    If they're anywhere near the PSU, move them.
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    try grounding ur power inverter to a different location, mine did the same thing and that fixed it right up... Do you have it plugged into the cigarette lighter?
    Feb 2007
    thanx for the help guys.. problem ended up being , that the inverter was to close 2 the amp,, so i moved it to the back seat and about 90% of the sound went away, so all good.
    Aug 2005
    Pennsylvania
    Another problem could also be that the gain on your amps are too high if your computer is ran directly to them bypassing a headunit.
  1. Replies: 0
    Last Post: 02-16-2006, 02:48 PM
  2. Rear speakers not going :(
    By samael in forum Car Audio
    Last Post: 08-13-2005, 03:33 AM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  4. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 12:04 PM
  5. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
