Most shutdown controllers with a relay will work in conjunction with an inverter. The wiring will be pulled from either your fuse panel, your main feed to your inverter, or some other 12V line (for the main feed), and if you need an ACC line you can also pull that from the fuse panel, radio harness, or another location where ACC power is present.
LinkBack URL
About LinkBacks
