oh ya, an i have no intrest in wasting a perfectly good PS
MIKE!!!![]()
I know it would be simple to cut some wires and put an ATX plug on the end. i would be missing the 3.3v nd i'm guess that just leaves me with less fuctionality. (power off/on)
If there's an easy way to get 3.3v, thats great. but in the meantime, i just got this via 800 board and the Arise AT PS sitting in front of me.
I'm sweating bullets here. Am i going to screw up my board by doing this? or is it even worth it>?
MIKE!!![]()
MIKE!!!![]()
You will need 3.3v, its used to power the CPU amongst other things. However, you can just get a 3.3v reg and power it off the 5v line to get 3.3v (as is done on-board by AT motherboards). As long as you wire the pins correctly yes it will work.
(=========-) 99% complete
AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
All jammed in external CDROM drive case.
Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
thats just a radioshack part? I can do that. Sweet. thanks!!
MIKE!!
Also, The arise is 65 Watts. Does the 800mHz and Via pull more than that?![]()
I think I read somewhere here thaat the actual VIA 800 cpu draws only about 18 watts, compared to an Intel cpu at about 60 watts. Try searching, it was only about a week ago.
So would Mastero be willing to provide a ready made adapter kit to make this work?
I would also like to use my AT DC/DC PSU!
1983 BMW 733i
Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
Gathering parts for carplayer v2.0!
Mastero Sells the AT -> ATX plug on his site. Thats what you can use if you want the board to act like an AT. He also mentioned building a ready made kit that converts the two about a month ago. Not sure where he is with that, but i definatlely could use a couple.
18 watts sounds great to me! Still waiting for my board to get in...
MIKE!
Have a look at this thread for more info than you'd ever possibly want.
:edit: corrected spelling mistakes
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
