Is your usn hub powered or capable of being powered? If so, you should make a barrel plug for it and use the 5 volt rail from the computer's power supply to suffice the power comsumption of your usb devices. Im assuming you're using an external drive enclosure since you said that you can plug it into one of the usb slots on the hub? If so, there should be a power plug on the enclosure. You can also make another barrel plug using another 5 volt line from the computer's power supply and power the drive also.
A non-powered usb hub is not going to do you any good when the touch screen itself already uses 500ma, which is what a non-powered usb hub would be splitting. Powering from a 5 volt source, ie. computer's power supply, would enable the hub to be able to use 500ma per slot.
LinkBack URL
About LinkBacks
