Results 1 to 4 of 4
Thread: switching from inverter to DC-DC (Help plz)
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    OK currently i have a 400watt inverter powering my computer the current PSU is 350watts....
    it is a little XPC made by shuttle, the model is SD31P
    i want to buy a DC-DC psu with shutdown controller... any ideas which would work best?
    Elsewhere
    How about the Wiki?
    Apr 2006
    Join the club. i'm also using a 400 power inverter. the power supply is only 250 watts. my pc currently draws about 180 so im stuck. all the dc-dc psu's at that wattage are too expensive. you need to get your power draw below 160w and then your options will start opening up. right now i think your system draws way more then that. what are your specs on the pc.
    you could use something like this calculator to help you out
    http://carpc.kyferez.com/Tools/PSUWattageCalculator.php
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    The "expensive" prces on opus and the DSATX PSU's are there for a reason....
    1. They have more output than the cheaper ones (duh)
    2. And most important, they're far more relible and have important features the cheaper ones don't have.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  1. KITT - It had to happen sometime!
    By prefim in forum MediaCar
    Last Post: 08-22-2010, 10:39 PM
  2. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 03:20 PM
  3. Setting up a swtich to turn off inverter when computer turns off
    By hd54321 in forum General Hardware Discussion
    Last Post: 11-29-2004, 03:36 PM
  4. Plz help me with shutdown + inverter....I'm almost there.
    By falconey in forum Power Supplies
    Last Post: 09-09-2004, 12:06 PM
  5. inverter or DC PC Power supply?
    By qdrw82 in forum Power Supplies
    Last Post: 11-07-2003, 06:00 PM
