Results 1 to 5 of 5
Thread: M2-atx
    Newbie scaff's Avatar
    Feb 2007
    M2-atx
    Hi, does anyone know if this power board could connect to a laptop ?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by scaff View Post
    Not unless your laptop has an ATX connector...
    1.9in x 2.9in -- 47mm x 73mm
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by 2k1Toaster View Post
    And guess what ... it doesnt
    New Age Garmin - Skin for RR
    Sep 2006
    Actually, I'm using an m2-atx to power my laptop carpc right now. It just takes a little bit of chopping/soldering wires. You'll need also need the car charger for your laptop (or any generic on on ebay).
    I only used this because I already had it, and I'm on a budget. There are other ways to do this, but I wanted the startup/shutdown controller and voltage regulating properties of the m2atx.
    I'm powering the +12v input of the car charger with the +12v 4 pin connector. I'm powering everything else (TS, usb hub, external dvd-rom) with the +12v and +5v lines off the ATX connector.
    The only thing you have to do to get your m2-atx to "turn on", is to ground the green wire on the atx connector.
    There is still a kink with the startup/shutdown controller aspect of it, but I'm working on that. I just hooked up the power switch port on the m2-atx in parallel with the switch on the laptop. In theory it works fine, however I'm having difficulties, I'm working on it though.
    Elsewhere
    You could use an M2 (or other ATX-compatible PSU) hacked to pieces or you can spend about the same amount on a PSU that's designed for the laptop....
    Hmmmmm....
    I think I'd go with the latter option, thank you.
    How about the Wiki?
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 09:04 PM
  2. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
  3. M2 ATX - EN15000 - USB - Problems!
    By BulleDK in forum Power Supplies
    Last Post: 12-28-2006, 04:29 PM
  4. M2 ATX Manual
    By lanman1 in forum Power Supplies
    Last Post: 08-16-2006, 02:28 PM
  5. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
