1) The mode that the PSU is in is determined within 3sec of powering up. In other words, the logic routine for the PSU runs through it's course within 3sec.
2) Use two wires of a higher gage to allow for more current. I agree that this is pretty silly.
3) Too many questions for this number!
you have to jumper positions. Using the chart in the manual, you determine where to put jumpers for different lengths of time. you're correct that you leave the jumpers off got a delay of 10sec.
Startup voltage is how much voltage needs to be on teh ACC line in order for the Opus to initiate startup. If the ACC line supplies less than the set voltage, it won't power on the PC.
And I can't look in the manual to see what it says about the shutdown delay,
4) That is correct. It connects to the motherboard power switch header.
LinkBack URL
About LinkBacks
