Results 1 to 10 of 13
Thread: DSATX and amp turn on lead...not turning off
    _
    Mar 2004
    Little Elm, Texas
    New install, new carpc, new PSU. Everything boots up just fine.
    When I pull the key, the computer shuts down as it should....but the amps don't, neither does the alpine processor. In otherwords, the turn on lead won't turn off.
    I have a brain stem hooked up and I can go into hyper terminal no problem. Here's my current settings:
    033.8:12.28:11.93:05.08:0.3.33:10.07:0000:YYYY:2:0 000
    However, hyper terminal isn't accepting any of my keybaord commands so I can't pause the feed to input any new data or to get to the advanced commands.
    I see from the manual where I need to set EARLYAUXCUT to 1 (yes), but I can't get there.
    Any ideas?
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    So I've tried Tera Term now too, no dice.
    No keyboard commands are going through.
    Anyone?
    Part of me wonders if I might have switched the ground and the logic-in pins when I created a new cable, but then I think about how it would even send information if it weren't grounded...so this doesn't seem like it would be the issue...unless it's grounding through some other means?
    Jan Bennett
    Apr 2001
    Portland OR
    Quote Originally Posted by RedGTiVR6 View Post
    Anyone?
    Can you test it with the brainstem plugged right into the DSATX?
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Try changing your flow control to either off or Xon/Xoff i've had that keep me from entering serial commands into hyperterm.
    肚子笑痛了
    S60 Install
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by zootjeff View Post
    nope - I've just tested continuity between all of the pins (from the back side of the brain stem to the back side of the PSU) and all pins are continuous.
    I've also traced all wires and confirmed that everything is wired up correctly.
    I've tried switching things around and when I do I lose the feed, so I know it's all hooked up correctly.
    Still no dice.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by jcdillin View Post
    tried this too and it's not working.
    Jan Bennett
    Apr 2001
    Portland OR
    How do you have AUX OUT connected? Are you using a relay?
    www.mpegbox.com
    _
    Mar 2004
    Little Elm, Texas
    yes, this relay:
    http://www.thesourcecc.com/estore/Pr...roduct=2750249
    Doesn't sound like the relay can be bad if it's turning everything on. And if I were wired up to the wrong output, it would turn the amps off when the computer is turned on and when the computer is turned off the amps would come on.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    I unplugged J1 while the computer was running and I can hear the relay click. So I know the relay is good.
    I've also tested continuity between the PSU ground and this pin throughout the shutdown process. It's continuous with the computer on, through shutdown, and with the computer off.
    If the PSU is programmed right, then it should have ground when on, no ground when off. Correct?
    Jan Bennett
    Apr 2001
    Portland OR
    Can you give me your optimal behavior of AUX out?
    Sleep: ACC Low, Rails Off, +5VSB OFF, AUX is ( OFF )
    Startup 1 : ACC High, Rails OFF, +5VSB ON, AUX is ( )
    Startup 2: ACC High, Rails ON, Startup Pulse Sent, +5VSB ON, AUX is ( )
    Running : ACC High, Rails ON, Computer Running, +5VSB ON,AUX is ( )
    Countdown : ACC Low, Rails ON, Computer Running, +5VSB ON, AUX is ( )
    Shutdown 1: ACC Low, Rails ON, Shutdown Pulse Sent, +5VSB ON, AUX is ( )
    Shutdown 2: ACC Low, Rails OFF, Computer OFF, +5VSB ON, AUX is ( )
    Fill in the AUX is ( ON/OFF ) blanks. Note any desired behavior.
    www.mpegbox.com
  1. DSATX won't power Amp without upgrade?!!
    By XcompX in forum Power Supplies
    Last Post: 10-25-2006, 12:15 PM
  2. DSATX F1&F2 Amp hookup
    By dsballer2000 in forum Power Supplies
    Last Post: 06-29-2006, 05:32 PM
  3. dsatx issue
    By gameboy in forum Power Supplies
    Last Post: 02-25-2006, 05:12 PM
  4. DSATX not powering up
    By alti in forum Power Supplies
    Last Post: 10-30-2005, 12:37 PM
  5. DSATX Review
    By parvo99 in forum Power Supplies
    Last Post: 10-28-2005, 06:25 PM
