OK - here's what I have found... first, my 8.99 multimeter from Rat-Shack is a pos. So I brought home a Fluke from work and got much better results.
Other than that... here's what I see on the AC
power supply when it is plugged into the wall and into the mobo - wanted to make sure you could see any difference it made with the mobo attached. If I need to only read from the PS let me know and I can do that too.
Notes on this image:
1. "Gnd / No Gnd" is the result of me
testing continuity between the chassis ground and the pin.
2. All voltages were measured between chassis ground and the pin.
3. On pin #8 - when I was reading continuity(resistance), I found that shorting (well actually, just me putting a lead on he pinand the ground) caused the PS fan to go on high instead of the normal idle speed.
4. Image is if you are looking at the connector the same way fritz_fx is holding his in the second image above.
Hope this makes sense - let me know if it needs clarification.
Thanks for the input so far!
