actually USB hubs are 5volt, not 12volt..... What you could do is run your hub via the 5v of your DC-PSU.
Hi.
I have hit the limit of usb devices now and I need to run a hub. Trouble is power. Should I just run a power inverter like this and plug the hub power into that or is there a better way?
EDIT: Ignore me, I clearly need to enhance myskills! I've found the best solution will be to chop off the ac/dc adapter plug and wire the hub to my existing carnetix power inverter
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Bluetooth, 802.11g, GPS
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
NLited XP with Road Runner and MapMonkey
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
So the cnx p1290 5v output would be the best option would it?
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
it could be. look at the info i provided here:
Using the Carnetix P5V to only shut down USB devices once the computer is OFF
