Results 1 to 10 of 19
Thread: Carnetix P2140 & Dell sx260/270
    May 2004
    South Florida
    Hi,
    I would like to use a Carnetix CNX-P2140 with a Dell sx260. In addition to the Dell I would like to also power a USB hub and xenarc 7" from the power supply.
    From previous posts, the Dell has a 150watt power brick.
    I have soldered a wire from the power button and extended them outside the case (for shutdown controller). I would rather use the standby feature than hibernating the PC. My install does not include a stereo and sometimes have to make a number of small trips. My car currently has in a Via M12K with a Opus 150 but need a bit more power.
    Will the CNX-P2140 work for this setup?
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    It seems like it should, why not? I'm not sure if you can have three different volt outputs as you wanna do. But you can always power up the monitor from the car's supply.
    Seems fine to me.
    08 Lincoln Navigator www.mobiteklink.com
    May 2004
    South Florida
    Thanks, ordered 1 yesterday and plan to install this weekend.
    Should have PC swapped out this weekend. Will post results once I have completed it.
    Jun 2005
    Queens, NYC
    Please post the review
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    what wires do you connect to the power button and what wires are used for sensing the computer is powered on.
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    Carnetix p2140 Installation Question
    Here is my thread giving a short summary how to connect the carnetix to your SX260/270
    Constant Bitrate Bump's Avatar
    Nov 2004
    Chambersburg, PA
    Quote Originally Posted by BasicEvil View Post
    Hi,
    How many volt does your Power brick work on now.?
    Right now P2140 can only out put +12V, +18.5V, or +20Volts .
    Mike is working on a way to upgrade the P2140 to be able to out put 12-20 Volts in 1Volt hops.
    He is doing it to be able to power the Laptops that are 14-18 Volts.
    Here is the Manual
    Carnetix P2140 Manual
    Aug 2006
    West Allis, WI
    THis should work fine. The only concern I would have is leaving it in standby mode. Doing this will definitely drain your battery more than you want it to. I would suggest a second battery that is isolated after ignition is off thus preventing your main battery from draining and allowing your car to start.
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    something to keep in mind. Most notebooks accept a wide range of voltages.
    The one in my car will work anywhere from 14-22vdc
    If its under 15 volts the notebooks battery wont charge. You have to get the technical docs of your notebook to see what it really supports and what's optimal.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    Nov 2004
    Chambersburg, PA
    Quote Originally Posted by ThunderStick View Post
    You can tell P2140 to shut down the Computer , then the Power supply at a set voltage. ( mine 11.2 ) . that way you can never drain your battery dead. And still start the car.
    P2140 default is ON & set at 11.8 when you buy it.
    one other thing to remember is that if P2140.
    can not produce 12 Volts prime and 12v sec. power outputs
    You Can only produce 12v on sec. output when you have higher then 12v on you Prime output.
    You can always just buy a small 12Volt power supply for just your screen.
    It sounds like you have the Laptop & screen running off one power supply.
  1. FS: Dell laptop power supplies
    By wrxmaster in forum Classified Archive
    Last Post: 08-10-2006, 09:41 PM
