Results 1 to 2 of 2
Thread: Having a few problems with my set-up
    Feb 2007
    i recently purchased my mac mini ( g4 1.5 processor) and i am using the mac pac along with the p1900 power supply ( version 2.2). Basically the problem i am running into is that power supply will boot up fine, it flashes until 60 seconds or whatever that time is then it flashes very very fast once the computer starts to boot up. I noticed also that it will stay steady if the computer is not powered on.
    I have set the jumpers to both 12v and tried 5v, both with the same results. Could this be a problem with my jumpers, or the unit itself.
    j1- 1 open
    2 deadman on
    3 sleep on
    4 open
    5 open
    j2 12v
    j3 open (default? there was no jumper on it in the first place)
    j4 dlyon
    j5 both on 12
    j6 is open for 18 volts
    j7 ( came with a jumper on it but i have no clue what its for)
    Now i had this hooked up with only a mac connected, no screen. Also it was hooked up in my home with a battery charger, not an actual 12v source but i did check the voltage and it was fine.
    Any suggestions or help would be greatly appreciated.
    Jun 2007
    Flagstaff AZ
    maybe i'm not the only the flashing the problem? or is the pc not booting? please clarify, i'm looking at the same setup for my car, and as you probably know any info is helpful.
  1. Slim dvd drive problems. JAE 50pin to IDE at fault?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 08-16-2007, 04:06 PM
  2. Still having XMPCR problems
    By rjoek in forum RR Bug Tracker
    Last Post: 09-23-2005, 01:08 PM
  3. Winamp volume problems
    By froop in forum Road Runner
    Last Post: 09-17-2005, 11:02 AM
  4. Major Electrical Problems
    By techy101 in forum Off Topic
    Last Post: 07-11-2005, 09:47 AM
  5. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 04:04 PM
