Results 1 to 10 of 10
Thread: DSX12VD power issues
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    I recently purchased a DSX12VD from mp3car.com It worked fine then it blew my motherboard. I suspect the PSU anyway, nothing else changed. Then I went to try it again on a different PC and no power. just wondering what might be wrong with this thing. I checked the fuse and it is fine. I checked power at the fuse and I get 12v. I checked power at the power header molex connector and I get nothing. accessory wires it powered and connected right. still nothing. Turned the count down timer (p1) all the way down and still I get nothing.
    Any help is appreciated.
    New Age Garmin - Skin for RR
    Apr 2001
    Portland OR
    Quote Originally Posted by ThunderStick View Post
    Measure the voltage at VIN and ACC, make sure both are 12 volts.
    Make sure you have a good ground.
    Make Sure P2 is turned all the way counter clockwise (don't over turn).
    Do you get an LED? Any blink codes?
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Aug 2006
    West Allis, WI
    I checked all the voltages, acc = 12v vin = 12v ground = good
    no blink codes.
    Just turned p2 all the way counter clockwise. Still nothing.
    Apr 2001
    Portland OR
    no blink codes.
    Can you think of anything you might of done to the the unit? Did you have stray wires floating around or anything? Can you take a picture of the setup? You have disconnected everything and let the unit completely power down right?
    Do you have a volt meter? I can give you some probe points..
    -Jeff
    www.mpegbox.com
    Aug 2006
    West Allis, WI
    I removed the white molex connector and soldered the wires direct. That is the only change I made to the unit. The reason I did that is becuase the molex connectors were to big and wouldnt fit in my case as is.
    Aug 2006
    West Allis, WI
    FRONT OF PSU
    FRONT OF WHOLE PSU
    Back of PSU
    I did use RTV to secure it to the computer case. Inbetween the psu and the case I but cardboard to prevent any shorting. That is what you see in the pic.
    Yes the RTV was completely dry before I powered it up. I waited nearly 24hours.
    Any ideas for me.
    Probe points would be helpfull
    Aug 2006
    West Allis, WI
    Anyone have ideas on what went wrong?
    Apr 2001
    Portland OR
    Try probing Pin JP1 A1 See if there is 5 volts there when ACC and VIN have 12 volts on them.
    Sounds like the microcontroller got fried somehow if you don't get the LED to turn on. Did anything short to J2 or JP1?
    www.mpegbox.com
    Aug 2006
    West Allis, WI
    the only thing I had connected on jp1 was the motherboard on switch.
    mp3car told me to send it back, so i am
    Apr 2005
    Did you ever figure this out? Are you still using the dsx12v?
  1. Power Supply crank issues
    By jaytyn in forum Power Supplies
    Last Post: 11-03-2005, 12:44 PM
  2. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 10:32 PM
  3. Why the 5400 RPM hard drives? Power issues?
    By thenewuser in forum Newbie
    Last Post: 04-30-2005, 08:02 AM
  4. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 01:16 PM
  5. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
