Results 1 to 10 of 19
Thread: Wire Size Dropping.
    Aug 2005
    Wire Size Dropping.
    Ok so im planning on running one large wire from the battery to the distro block like suggested by most.. Heres my issue..
    Ive never found a distro block with 16/18GA outputs. The opus wires are 18GA. So if i run 8GA out of the distro block (the smallest i can find) should i then fuse it when the wire size drops?
    Cheers guys
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by SKiTLz View Post
    Cheers guys
    Well you don't have to, but if you get a distro block with no individual fuses, then the guage change presents the perfect opportunity to individually fuse all your stuff. Of course a main fuse by the battery is still required too.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2005
    Quote Originally Posted by 2k1Toaster View Post
    Ok.. The distro block is fused so that should be fine then.. Great. Thanks mate..
    I want a clean install so i've been reading like a mad man on electrical connections and doing things right.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Technically a wire should be fused whenever there is a drop in size.
    I'm pretty sure you can still connect your 16/18 AWG wire to the disrto. The distro will hold a max of 4 AWG, but will work with smaller wires as well.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Feb 2005
    East Bay, Cali
    RE: Fuses keep your car from burning up!
    Everytime you change wire size, you change the maximum amount of current the circuit can carry. Too much current and you risk melting the insulator on the wire and starting a fire. Imagine if those wires under your seat and carpet shorted out and the fuse does not blow. You will have problems.
    The fuse at the battery is to protect all circuits from the fuse. The fuse when you change wire sizes protects the circuit where the wire size gets smaller and can carry less current
    The recommended maximum fuse for a 16-gauge wire is 7.5A. See this site:
    http://www.bcae1.com/wire.htm
    Good luck
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    Yes my distro is 3 x 8g outputs but you could use some 14g out of it. Just might look small to the hole but splice back enough wire and shove it in and tighten it down. It will be fine.
    YES always use fuses when you can
    10 acura TL tech
    10 BMW S1000RR
    Aug 2005
    Great guys.. Appreciate all the input...
    Will post some pics of how it all goes..
    Jul 2002
    Blue Sea Systems makes some very nice distribution blocks with fuses. They have studs so you need crimp terminals. Makes for a neat installation if you have several circuits.
    _
    Mar 2004
    Little Elm, Texas
    terminal strips are a good solution too:
    http://www.mj-garage.com/cpg/display...lbum=68&pos=43
    Jan Bennett
    Aug 2005
    Quote Originally Posted by RedGTiVR6 View Post
    I just went through your page. SUPER Clean install. Something id be proud to have in my car.
    Unfortunately i dont think my skills are up there for something of that cailber. I still dont full understand the concept of a terminal block. And i think im going to wear google out with all my searching.
  1. '97 5-spd Maxima, first carputer attempt...
    By wasyed in forum Worklogs
    Last Post: 11-30-2006, 04:41 PM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  3. Dsatx
    By CENIZERO in forum Power Supplies
    Last Post: 05-20-2006, 03:44 PM
  4. Pure oxygen free wire?
    By Gearhead61 in forum Car Audio
    Last Post: 04-25-2006, 02:49 PM
