Results 1 to 4 of 4
Thread: Changing the Jumper values on a M1ATX
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Is it possible to change the timings on a M1ATX I do have a programmer knocking about somewhere, but I have zero knowledge of pic's etc.. what I'm after is using Suspend (s3), but if I dont start the car say after 24 hours the M1 then goes into HardOff.. this would then save my battery draining until it was below 11v's has it struggles then turning over my engine ?
    What I'm after is..
    Jumper 3 changing from
    5sec / never
    to
    5sec / 24hour
    can this be done
    cheers
    CdR
    Sep 2006
    Im kinda curious about this too on an M2ATX instead, a software shutdown timer that actually interacts with the PSU would be great
    Feb 2004
    Manchester
    been running standby for a week now... very very pleased so far.. near instant turnon (3 seconds) and no flat battery as yet.. although I do make sure it cuts off when I put it in the garage at night.
    CdR
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Yes, it definitely can be done. The firmware was posted a year back or more. If you can figure out PIC assembly, you should be able to adjust the timing constants to suit your needs. I have a port to C (forget which compiler I used) laying around here somewhere. IIRC, I made it functionally equivalent to the OEM firmware (probably an older version) but I never got around to giving it a thorough test. My ultimate goal was to add a serial comm link from the PSU so that dynamic PSU settings and monitoring could be implemented (based on GPS location or other user supplied feedback for instance). Fortunately the OEM firmware suited my needs and I never got around to finishing -- you're welcome to it if you want.
    Quote Originally Posted by CdRsKuLL View Post
    What I'm after is..
    5sec / never
    to
    5sec / 24hour
    can this be done
    cheers
    CdR
  1. jumper settings for m10000
    By Transamsfast in forum General Hardware Discussion
    Last Post: 01-22-2007, 09:50 PM
  2. Changing MT fluid....my self?
    By sdashiki in forum Off Topic
    Last Post: 04-27-2006, 04:10 PM
  3. Removed Jumper from Mii10k - Mono Audio
    By buurin in forum General Hardware Discussion
    Last Post: 03-08-2006, 07:52 PM
  4. opus 120w jumper help
    By nxhorr in forum Power Supplies
    Last Post: 08-21-2005, 09:11 PM
  5. Where can I buy pins and jumper leads from?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 03-27-2002, 01:57 PM
