Results 1 to 10 of 19
Thread: Ground to Negative???
    Apr 2006
    I've read two seperate things and am unsure whats right.
    Some people say you should connect the ground to the car chassi.
    Others say the ground should connect to the Battery Negative terminal.
    Basically I have an amp which has +12v, and a Ground. Additionally I also have an inverter which has + and - points.
    I assume the ground and negitive points of both devices are the same thing just called different things.
    I so then: What and where do I connect the negitive terminal of the inverter and the ground wire from the amp???
    Elsewhere
    Either will work.
    The idea behind grounding to chassis is creating a shorter ground path, which is easier to connect/disconnect, and involves less physical wire.
    How about the Wiki?
    Apr 2006
    just what I wanted to hear, thanks...
    Why some devices refer to ground as negative, or negative as ground, I dont know...!
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    negative isnt always ground. AFAIK...
    we do have 3 prong plugs in our houses?
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    Quote Originally Posted by sdashiki View Post
    The current in your house is alternating + and - that is the reason you use a third wire for the ground, for the purpose of preventing the item from getting fried due to an electrical surge from things such as lightning... Your vehical uses a direct curent, one wire will always be + and the other will always be -, the reason you "ground" your negative to the car chasis is due to the fact that the chasis is used for the negative in the cars electrical system...
    Aug 2004
    Floreeda
    Duh, im stoopid, didnt even contemplate the AC/DC differences.
    Oct 2006
    Texas
    Dont be so hard on yourself man....
    _
    Mar 2004
    Little Elm, Texas
    The reason some people will ground to the negative battery terminal is that on average, the chassis of your car is only equivilant to about a 4 gua wire.
    That and grounding to the battery eliminates the possibility of ground loops.
    If you do ground to the chassis of the car be sure to follow proper procedure. Keep the ground as short as possible and be sure to scrape away any and all paint. Ground to bare metal and for petes sake, don't just use a metal screw for this. Use a nut and bolt.
    Jan Bennett
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Quote Originally Posted by RedGTiVR6 View Post
    The reason some people will ground to the positive battery terminal
    Positive?
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by ijwalla View Post
    To confused you even more. In other place in the world, it also called Earth.
    Ground, Negative, Earth are all the same thing (well for DC, it is.)
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Induced noise/Ground loop trouble shooting guide.
    By Will Albers in forum Car Audio FAQ
    Last Post: 01-28-2011, 09:37 AM
  2. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  3. I tried everything, can't get rid of this ground loop
    By intense in forum General Hardware Discussion
    Last Post: 07-10-2005, 09:58 AM
  4. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  5. Finding good ground to prevent Ground Loop
    By lookinco in forum Power Supplies
    Last Post: 11-04-2004, 02:23 PM
