Results 1 to 10 of 11
Thread: m2 and dsatx not posting anything but when i
    Feb 2007
    yeah i have treid both my power packs and they were not posting at all yet a while back the m2 was but nothing now...
    today i was reading a post on here and it sed something about a standard computer hard drive can use more more then u have....
    so i went down to my car and unpluged the hard drive..
    yes the computer posted to bios....
    so what can i do now are there hard drives out there that are smaller ie laptop one and run on hardly and watts... ???
    plz help me its bin 4 months now since i started this and iam on the verge of giving up completly
    Newbie PatrickJW150's Avatar
    Feb 2007
    Yeah, the 2.5 inch hard drives we sell are laptop hard drives. I'm curious to know what else your running in there that has you so close to 160 watts already?
    Feb 2007
    so will getting a laptop hard drive help..???
    not alot in ther really just my m/b, hard drive, with one usb wire going to the touch screen and thats about it....
    thats all that runs of my dsat..
    whilst unplugged at the mo i have a 1600w amp. 2 1200w 12" subs, sat nav and usb tv.
    just dont no y iam not getting enough power to boot the comp on the screen.. whilst taking the hard drive out makes it work.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    What is your mobo/cpu combo?
    Also, unplug the amp and see if the carpc boot up and function.
    I'm thinking that the PSU doesn't get enough power. So you either run BIGGER wire from the battery to the distro block and branch it out to the amp and carpc.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Feb 2007
    the amps arnt connected the 10g power wire for the psu runs staright to the battery no dist block....
    Elsewhere
    Again:
    WHAT ARE THE MOTHERBOARD/CPU/RAM/HDD YOU ARE USING?!?!?!?
    Please forgive my outburst. We are trying to help you pinpoint the problem. Part of that troubleshooting process is information gathering. If the cause of your problem is too high a power draw, then the details of your PC setup whould help us to diagnose that.
    Help us help you, amigo.
    How about the Wiki?
    Feb 2007
    my computer is of the following...
    VIA EPIA M10000 Nehemiah Mainboard (1Ghz)
    Kingston 1000MB PC2100 266MHz DDR Memory
    DuraWatt Dsatx 220w dc-dc atx psu
    160g Hitachi Deskstar Hard Drive Running xp
    Sep 2003
    Beach City, Socal
    Use a meter and check what is the battery voltage AT the PSU. It shoudl be about the same voltage reading as it was AT the battery.
    Also check the output reading on all power rail from the PSU (5V, 3.3V, 12V...)
    Your setup probably only uses half of what the DSATX capable of.
    Elsewhere
    If the PC isn't POSTing using a DSATX, then something is horribly wrong.
    How about the Wiki?
    Feb 2007
    well today i checked all the rails and they are all fine, iam going to see if its the monitor side of things next....
  1. M2 ATX Problem
    By v8 scimitar in forum M2-ATX
    Last Post: 10-12-2010, 01:21 PM
  2. Dsatx Rules!!!!!!!!!!
    By trickyuno in forum Power Supplies
    Last Post: 02-11-2006, 09:01 PM
