Results 1 to 10 of 10
Thread: Athalon XP 3000+ and M2-ATX
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    I currently have a Via MII 10000 ruing street deck but am thinking about upgrading to my shuttle mobo with a Athalon XP 3000+ and a 1u server heat sink.
    Will the M2-ATX be able to power a Athalon XP 3000+? Would under clocking it help?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Maximum Bitrate DeltaFX's Avatar
    France
    Bang ! Athlon XP3000+ is rated at 45A @ fsb=333 & 41.4 A @fsb=400
    good luck using a M2
    Buy a geode NX 1750 cpu instead.
    Now Galileo is real. Muhahahahaha :p
    Elsewhere
    Theoretically, is will work, however you're going to have very little power left over on the 12v rail for other devices.
    If you run the system with a laptop HDD, I'm pretty certain it would work.
    How about the Wiki?
    Sep 2006
    You're probably batter off using the opus 250 or the 320.
    05 Acura TL
    CarPC 99.99% Done
    Elsewhere
    I run an AthlonXP mobile 2400+ on a Shuttle FN41 with a 1u heatsink. IT's powered by a DSATX and runs just fine, with lots or pwer to spare. Granted, I'm running a mobile processor.
    I would try to latch onto an AthlonXP mobile CPU, assuming you can find one. They use less power, which is what you want in the car. They also generate less heat, which is another benefit in the car.
    I agree with KingofCoronoa that a higher-rated PSU would be a good idea. I think the 320w Opus is probably overkill. The 220w DSATX or the Opus 250w would most likely serve you well. Just go easy on the video if the Shuttle doesn't have it onboard.
    How about the Wiki?
    Quote Originally Posted by DarquePervert View Post
    I think its the same board you have the dual vga...
    right now i have the via, laptop hdd, lilliput, gps, amp turn on, powered by it.
    I'm going to power it up when in the house and see what options i have for under clocking it.
    1990 Jeep Cherokee
    I also have a old system with a 900mhz Duron cpu do you think that would be a better option? i bet even though its slower then my current system it would be faster...
    1990 Jeep Cherokee
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The Athlon 3000+ will EAT the M2-ATX alive with smoking flavor.
    You will be better off with the DSATX or the 250 Opus.
    My Matrix setup on the DSATX barely make it on the 5V rails.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    looks like im just gona get a Jetway AMD Geode 1.4 GHz 533FSB Mini-ITX Motherboard since i can use the PCMCIA board on it...
    1990 Jeep Cherokee
    Feb 2007
    I'm running a Sempron 3300 with an ASUS K8V-VM off an M2-ATX, with a samsung 2.5" 80gb, and have had not a single problem. I believe the Sempron probably uses less power than the old Athlon XP though.
    This CPU/MB combo was DIRT cheap here, $130AUD brand new.
    *ST185 Celica GT-Four Group A Rallye (Alltrac Carlos Sainz edition)*
    http://www.mp3car.com/vbulletin/worklogs/96292-my-first-carpc-1991-celica-gt4-group-a-cs.html
