Results 1 to 10 of 11
Thread: Correct Metric Gauge Wire to Power Opus 150 Watt (Australia)
    Constant Bitrate long.1's Avatar
    Jul 2006
    Melbourne, Australia
    Hi All,
    Whilst at my local "Super Cheap Auto" today (Australia), I thought I'd check out their wiring. To be honest, it only served to confuse me more, and I'm hoping someone can shed some light.
    I have an Opus 150 Watt that will be powering my Via Epia based system, and in the User Guide for the Opus it says to use:
    #12 AWG for power/ground
    #18 AWG for ignition
    Reading the very informative: FAQ: How to Wire an OPUS PSU, it quotes:
    1) You can use 10 gauge wire for the connections; I believe Opus recommends 12 awg. Most people use 10 to be safe, especially when running longer lengths to the trunk.
    2) Add the fuse to the fuse holder. You should use a fuse that is 15 – 20A, you don’t want to go higher then 20A
    Now whilst I probably won't be wiring into the boot/trunk, I still want to be "safe", and make sure I use the right gauge wire. The problem is that we don't use the AWG in Australia - our wires are metric rated (in “mm” and/or “mm˛”). So I've reviewed a number of AWG to Metric Conversion Tables such as:
    My confusion deepens upon looking at the wires today. The thickest one they had there was sized at 5mm. Reviewing the charts, this would seem to put it between AWG 4 and AWG 5. However, the wire cable also says 2.90mm˛. Again reviewing the charts, this places it between AWG 12 and AWG 13, which sounds borderline at best. To confuse matters even further this cable also says "25 amp".
    I've searched these forums for the answers and found threads such as this, but to be honest, I'm more confused than enlightened.
    So finally getting to my questions, I'm hoping for advice on:
    1) Which standard/gauge/rating should I be looking at - “mm” or “mm˛” ?
    2) Which size fuse should I use ? 15A, 20A, or 25A ?
    Thanks in advance.
    Cheers,
    Long.1
    Oct 2006
    Las Vegas
    Quote Originally Posted by long.1 View Post
    [FONT="Tahoma"]
    They both should agree, it's simple geometry.
    The chart you have shown is correct. I would get a measuring tool (micrometer or small, engineer's ruler) and measure for myself. Or find a more reliable source of wire.
    [FONT="Tahoma"]
    If you find 10AWG equivalent, use 20A, if you go smaller, reduce the rating accordingly.
    It's been a while...
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    the metric is mm sq not diameter or thickness which is why it doesn't measure out properly. For 20A you want 4mm sq which is a standard metric size
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Jul 2006
    Quote Originally Posted by h3rk View Post
    They both should agree, it's simple geometry.........Or find a more reliable source of wire..........
    Quote Originally Posted by v8 scimitar View Post
    Thanks all - greatly appreciated.
    I could definitely understand the maths for diameter/area, which was adding to the confusion.
    In any case, armed with your thoughts and my research, I'll head down to an AutoBarn or a Strathfield store on the weekend. I reckon they're more into the Audio and In-Car Entertainment side of things, so I expect they'll have a more comprehensive range and available staff. In fairness to SuperCheapAuto, this stuff is probably not their specialty, and the store I went to was in the middle of a total renovation.
    Thanks again.
    Cheers,
    Long.1
    Oct 2006
    Las Vegas
    I can't even visualize an australian starting off a sentence with the words 'I recon'. Funny.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Thanks again.
    Cheers,
    Long.1
    Definately go somewhere that has a better range of car audio stuff. Even try Dick Smith or Jaycar. They also have car audio gear.
    Just a note, we do use Gauge sizes (AWG) in OZ for car audio. Auto electricial guys mainly use mm squared.
    H3rk, You need to come here for a holiday. I can guarantee you'll leave saying it
    Oct 2006
    Las Vegas
    I intend to. In fact I thought I was going to when I joined the Navy, but I ended up locked up in a tube that may (or may not) have had several nuclear missles loaded in it, and not many foriegn ports wanted any part of that(nor our pentagon. Damn, I just got flagged.
    Oh well, one day.
    When I hear 'I recon', I picture Jeff Foxworthy or the like saying it, that's why I couldn't picture it.
    Aug 2002
    I can understand some cities not wanting a nuke sub in their ports. I suppose that is just the way it goes.
    Jul 2006
    Quote Originally Posted by meddler View Post
    Definately go somewhere that has a better range of car audio stuff. Even try Dick Smith or Jaycar......
    Will do - thanks !!
    .........When I hear 'I recon', I picture Jeff Foxworthy or the like saying it, that's why I couldn't picture it.
    Don't get much exposure to Jeff Foxworthy down here (apart from mates sending the odd video link via email). I do recall one "bit" though where he was a brain surgeon with a thick redneck accent - hilarious !!
    Jul 2006
    ....Even try Dick Smith or Jaycar. They also have car audio gear. Just a note, we do use Gauge sizes (AWG) in OZ for car audio........
    OK, the Mrs was hosting some clothing party our place tonight so I took my 3 year old boy out for a fun filled evening of wiring and PC component shopping - wasn't he just pumped !!
    Went to Dick Smith Superstore first - no joy. Then went to AutoBarn and wouldn't you know it, they had a choice of 8AWG or 12AWG. I chose 12AWG.
    I got 3 metres of each wire (power/ground) as I plan to run both from the battery. My pc will most likely be going under the drivers seat (I know, I know - I'll be taking precautions), and my car battery is on the same side of the car. So given this distance, will I still be able to use the 20A fuse, or will a 15A be better ?
    Cheers,
    Long.1
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. Replies: 1
    Last Post: 01-09-2007, 07:57 AM
  3. FS: OPUS 150 watt DC-DC power Supply
    By JWise1203 in forum Classified Archive
    Last Post: 04-04-2006, 12:59 PM
  4. wtb: Opus shuttle power supply, Opus 150
    By clean customs in forum Classified Archive
    Last Post: 10-11-2005, 01:11 AM
  5. Routing power button to front of PC. Can wire be too thick of gauge?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 09-27-2003, 03:32 PM
