First Let me state my carputer is working 95% correctly and i am just trying to brainstorm here what could be my problem.. Its a lil cold here and before i remove all my interior panels to get at my pc i want to make sure i have it all planned out.
Sometimes when i resume from hibernation and my frontend is loaded and i am just about to drive off the pc goes right back into hibernation. I then shut the car off start her back up and then i am good. It normally does it after the car sits overnight and it does not do it every day.. its not a loose wire because then it would do it every day or when ever i put the car into hibernation and then resume like filling up at gas station or just random driving.
Dsatx is setup to in basic mode . send hibernation or shut down pulse when i turn off ignition.. That works flawlessy just as i open the door pc is off
Now i have noticed that when i start the car that the pc does 1 reboot if i turn on acc first for a lil then start car. So i am thinking p1 or p2 may need a lil more adjustment
If i start car up with out waiting at acc ( just straight turn key then pc boots up or resumes without a reboot.)
Now could p1 and p2 be linked to my pc fully booting or resuming and then going into hibernation when i am about to drive off. I mean i got a good gps signal and find the track i want and next thing you know (
windows is hibernating.) I have not installed it yet but i have increased my switch lenght with cat5 so i can have a button up front to kill the pc or reboot and see the pretty led from the hd..
Its not the
power options in windows i even set them to never and it did it..
anyone have ideas i would sure appreciate it.
thnaks in advance
specs
pc is connected to headunit had engine noise +connected a radioshack groundloop isolator (noise is gone)
i have a dsatx wired it up with 10awg wire about a 12 ft run.
I have a brainstem(not connected though)
1 stick of pc2100 512mb
I have gx260 2.0ghz when not overclocked
1 usb 7 volt hub 4port hub on the 12volt rail
axiom sandpiper gps reciever on 5voltrail with hirschman antenna from mp3 car
i have 1 usb 1gb flash drive connected
i have 40 gb toshiba 2.5in drive connected
I have a xenarc 7in 700tsv on 12volt rail
thats all that is connected except brainstem
I use hibernation and xp pro full no more nlited
mobile impact as frontend
and ig3.0 as
software..
