I wired the computer cable as described below.
On the PSU Wire both Primary 12vouts together and both Ground Together.
Cut the cable in half between the
power brick and the connector.
Solder the leads you’ve just cut to the ends of that like this:
Red (12vin CPU) to Red (12vout PSU)
Brown (12vin CPU) to Red (12vout PSU)
Black (Ground CPU) to Black (Ground PSU)
White (Ground CPU)to Black (Ground PSU)
Also, solder the screen (Wire Mesh Ground) to black.
Fold the Green and Yellow wires back against the cable and tape them up.
Tape each join up individually, then tape the whole lot together.
