Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
Thread: Carnetix p2140 Installation Question
  1. #31
    Jan 2006
    Lexington, KY
    Quote Originally Posted by MAZDABOY View Post
    Wow, another VW guy. Seems there are a lot of VW fans around here. I myself have a 01 gti 1.8t also.
    I couln't tell from your name
    Yea, I'm pretty much a dub guy. So in to dubs that I want to change my name to Jay Dubs
    I've only noticed couple of dubs around. One of the mods/admins has a vr and someone with a MKV. I'm sure there's more but I don't really see anyone.
    Also, keep me posted on your progress. I think I will go with Carnetix 2140 for this sx270n.
  2. #32
    Jan 2006
    Lexington, KY
    Quote Originally Posted by ThunderStick View Post
    I wired the computer cable as described below.
    On the PSU Wire both Primary 12vouts together and both Ground Together.
    Cut the cable in half between the power brick and the connector.
    Solder the leads you’ve just cut to the ends of that like this:
    Red (12vin CPU) to Red (12vout PSU)
    Brown (12vin CPU) to Red (12vout PSU)
    Black (Ground CPU) to Black (Ground PSU)
    White (Ground CPU)to Black (Ground PSU)
    Also, solder the screen (Wire Mesh Ground) to black.
    Fold the Green and Yellow wires back against the cable and tape them up.
    Tape each join up individually, then tape the whole lot together.
    When you say Red to Red and Brown to Red do you mean the same Red or second Red wire?
    In another words would both Red and Brown (CPU) be connected to the same Red (PSU)?
  3. #33
    Jan 2006
    Lexington, KY
    Bueller ... Anyone?
  4. #34
    Apr 2005
    Should be the same red wire.
  5. #35
    Aug 2006
    On the computer
    I just picked up an SX270 with a P4 2.8GHz HT, 1GB RAM, 40GB HDD, Power Cable, DVD-ROM all that good stuff for $200 shipped. I dont know if thats a good price or not but it looked pretty good. Im about to order a P2140 to power this beast of a computer, any one have any other suggestions before I order this? How well will this work with the 2.8GHz HT processor compared to the other CPUs this can come with. Thanks a lot in advance.
  6. #36
    Jan 2006
    Lexington, KY
    Works perfectly!
    The longest I had it running was this past weekend for about 4-5 hours and everything was fine.
    BTW, that's a good price and for the most part that's what they go for.
  7. #37
    Aug 2006
    On the computer
    One last question, I was just thinking about this... I need a lot of the options this comes with to work with out a hitch such as: no "pop" through speakers when booting, then I want it to go into standby when ignition goes off and turn the PC on when I unlock my doors. I have read that some people have issues with these options how have they worked for you? Thanks again!
  8. #38
    Low Bitrate kirk78h's Avatar
    Apr 2007
    Bel Air, MD
    Never mind after a little research and a little risk I fuigured it out. The ACPI wires refer to the power button on control. Hook them up right and you have no problem. Green and White connected to your computers power button.
    I soldered wires on to the power button on the mother board
    OK, I'm really getting tired of pushing the power button on my SX270. I've taken the top off, and looked at the power button, but I have absolutely no clue where you are soldering the green and white wires. From the inside, it looks like the power button pushes down a very small white plastic plunger in a small black box soldered on the motherboard.
    With the power connected, I've tried just jumping the two sides of this box with a screwdriver to see if this made the connection, but it did not (someone posted that this is the way to find the connections -- I have no idea). This seems to be the only place to connect anything to. So, what am I missing???
    Please help -- this is driving me out of my mind!
    Kirk
  9. #39
    Constant Bitrate Bump's Avatar
    Nov 2004
    Chambersburg, PA
    first you guys should be going to the carnetix forum and post there . Mike will help you out right away.
    He will answer your question and fast.
    Quote Originally Posted by Jay_1.8t View Post
    I have posted the wires colors, above once .
    Red - Primary Output 1&2 (they both are the main power source ( computer ))
    Brown* - Secondary Output ( like screen,usb hub,XM,...any other thing you want to power )
    some computer ( like 18,24volt ) use 2 power wires to connect to the computers.
    12 V use one.
    that is why there are 2 power wire.
    Quote Originally Posted by BlackSunCeliGT View Post
    You will be fine. you will be shock to see how low of Watts yours computer will use.
    Get it you will be happy with. Just upgrade the flash on it. when you get it.
    1. speaker POP - just hook the " Blue (output side )- to a amp ( remote on wire ) " of the P2140 to your amps. There is a setting that you can change the delay time on he remote wire.
    No pop
    2. no problem with standby when ignition goes off. It is set up to do that.As one of the options.
    3. turn the PC on when I unlock my doors- That can be done. it is a little harder to do.
    a. you have to hook the Blue wire on the input side to a + side of the door lock. and set the input time to be set to make the P2140 to come on.
    b.if you dome light come on it can be hook to it.
    c. you can hook Blue wire to after market extra accessory wire.
    d.if you can start the car remotely it will work too
    Why not just let the P2140 take you computer out of standby when you start the car?
    Mine goes in to Hibernate mode. When I start the car . it take 5 -7 sec to be up . Time it take me to put on my seat belt. And that is a boot.
    With standby it should only take 2-4 sec to be up and ready to run. My screens take longer than that to start up and get warmed up to run.
    Quote Originally Posted by kirk78h View Post
    Kirk
    yes, the power button should have 2 wires coming out of it. that is what you solder/clamp/connect the remote wire to to turn it on. the solder can be done at switch, wires or MB
    it is better to try it with a wire instead of a screwdriver. jump it with a wire it will turn on/off.
    does not mater with side of the turn on button you put the G & W wire to. those two wire act as a relay and connects the power on button for what ever time you set the P2140 to hold it. If you had it to long the computer will come om and back off.
    ________________________________________________
    ok, please check Mike out on the carnetix forum. You will get great support from Mike.
    And if you have any more Question just ask.
    I own a car audio shop. And I have install at least 25 of them in the past 6 months.
    Not including the 4 installed in my Demo SUV and 1 in all 4 of my cars.
  10. #40
    Apr 2007
    Bel Air, MD
    Quote Originally Posted by Bump View Post
    Thank you for responding to these questions. My question is very specific to the Dell 260/270. If it used the standard ATX power supply connector, this would not be an issue. The wires would be very simple to solder. However, the motherboards on this PC have a very tiny switch soldered on the board that the power button depresses. There are no wires that I can see. There are no leads to solder to, unless I'm really missing something. The reason I asked this question is that Thunderstick posted in one of the first messages in this thread that he had soldered these wires successfully in one of these PCs. I would love to see how he did it, because I see no way to do it. If this can be done on one of these machines, please, please enlighten me.
    Kirk
  1. Carnetix P2140 & Dell sx260/270
    By BasicEvil in forum Power Supplies
    Last Post: 12-03-2007, 03:06 PM
  2. Carnetix P2140 PSU - Mac Mini
    By danielbriggs in forum Power Supplies
    Last Post: 01-08-2007, 09:45 AM
  3. Replies: 9
    Last Post: 03-31-2005, 02:40 AM
  4. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 12:27 PM
