Results 1 to 10 of 14
Thread: Vehicle Security and Tracking System.......... Designed and Manufactured by Mastero
    FLAC Mastero's Avatar
    Aug 2001
    India
    Hello Friends,
    It has been very very long time since i have posted on the site, The site has changed a lot since i last visited.
    Looks nice also.... good work guys !!!
    Hope all are fine and in good health.
    Ok back to the topic, I have designed and developed a Vehicle Security and Tracking System called "WATCHMAN"
    Below are the details. Contact me for further details and price.
    Cheers
    Mastero
    Aug 2001
    India
    WOW 100 views and no questions ??
    May 2010
    Herákleion, Iraklion, Greece, Greece
    i dont know dude. it seems pretty sweet! great job!
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    When you trigger the fuel pump/ignition cutoff is it instant? The reason I ask is that if done that way you will be in for a whole bunch of hurt from the lawsuits. You can only disable those items on next start not in motion. On-Star tells the driver that they will starting the graduated shut down and slow the vehicle down but this is all done via the ecm since they have complete control over their ecm. The best way is at the starter the trigger wire going to soleniod. And now the newer cars are only sending a 3v signal from ignition switch so it's not enough power to trigger, also that ignition wire is now going to the ecm and the ecm is sending out the trigger to soleniod. I do GPS tracking for a living and have been doing it for 12 years now. Seen all the new productas that make it seem so easy to add these features but in the real world they are really not that practical to implement. No client will pay for the 6 hours labour to hookup all the door locks,window opening/closing engine disable. Unless your labour rates are cheap and you are doing the installs at your shop with a hoist. Food for thought SNO
    Raw Wave
    Nov 2009
    Just a note - fuel pumps should never be cut off whilst the ignition if sparking.
    Nor should fuel pumps be cut off with injectors injecting (except perhaps for diesels).
    May 2012
    Grandville, MI
    Quote Originally Posted by OldSpark View Post
    Can cause your engine to run extremely lean and self destruct...
    And if this causes the damage your insurance carrier is not likely to cover it.. You might get your vehicle back but...
    Personally unless I can control it from a carPC I don't want one.. Plus I am sure its not cheap...
    Rodney
    Aug 2001
    India
    Hmmm nice question ...
    The fuel or ignition cut off is either instant or after next start user choice.
    Instant fuel cutoff will automatically slow the vehicle till the existing fuel in the engine is used. It is like running on empty tank.
    I don't think when you drive and your fuel tank is empty the vehicle self destructs.....!!
    The system can be installed by any D.I.Y person take a max of 3 hours to do it right.
    The cost is only 150 USD + Shipping
    Cheers
    Mastero
    Nov 2009
    Keswick,On Canada
    What redheadedrod is saying is if you cut off fuel while still having ignition connected will lean out the existing fuel left in the systems fuel lines and could cause problems. My concern is when you do that instantly cut either fuel or ignition you risk the lives of the driver of the vehicle as well as other's on the road. i.e highway speeds and car instantly shuts off vehicle could be in major traffic and cause accident or say they are passing someone and you cutoff everything (bad news). This may work well in India as the rules and regulation are not so controlled. In my area not many clients want to do it themselves and 3 hours labour will not complete 4 door lock/windows/fuel/ignition and starter disable along with the actual unit installation. I use mostly Enfora gps/gsm modems for my regular clients and the enfora's have 4 digital inputs 2 outputs and if thats not enough I can use the built-in pad to send out any data I need via the serial port. For my high-end clients I use Datalink's i50b satellite/gsm unit which has 3 serial ports and 4 analog/4digital in-out. I know most of these types of ideas come out of China. Have you seen how they get fuel levels? They say it's so easy but in reality you need to drop and drain fuel tank and drill a 1" hole in the top and add their float sensor (and hope you got all the metal filings out before you reinstall). Good luck on your project and I hope your sales are good. SNO
    Raw Wave
    Nov 2009
    Thanks Sno & Red.
    My reply merely reflected mechanical reasons as to why fuel pump cut offs are undesirable. I did not venture into the "safety" issues.
    Pardon my brevity, but it's a subject I tend to avoid because I'm sick to death of the morons I encounter on this issue {admittedly only on Australian forums, and often involving the related dead issue of "oil pressure control of electric fuel pumps and fuel supply" (except for diesels)}.
    As to the undesirable safety issue of cutting fuel supply etc, to me it's akin to cutting engines because of no/low oil pressure. Light an oil warning light or annunciator and let the intelligence of the driver decide if they want to kill the engine immediately, or get around the current drifted bend or off the railway crossing before killing the ignition/engine.
    Nov 2009
    Keswick,On Canada
    Agreed! On my system for the rare customer that pays me to do it (he's a small buy here/pay here car dealership), I disable starter but it is only on next start . He has never had to use that part of the system in 3 years. Now for theft its very good to have, but the better thing to have is a backup battery in a different location from the tracking unit and wired seperately to continue powering the unit so it can be tracked in a theft. Most of my installs are so hidden I even have a hard time finding them when client refreshes his fleet. I hate the thought of me selling a tracking unit to a client and the vehicle gets stolen but first thing the thief does is cut wires of an antenna or power. For a special purpose I have even installed 2 separate units in the same vehicle (trucking company hauling narcotics). Food for thought SNO
  1. Hardware Review: Connect2Car Anywhere G2 vehicle security system
    By Sonicxtacy02 in forum Mp3Car Blog Talk
    Last Post: 05-11-2011, 09:17 AM
  2. Vehicle Tracking
    By Gilbes in forum GPS
    Last Post: 03-18-2008, 11:29 AM
  3. GPS vehicle tracking
    By hubbard0705 in forum GPS
    Last Post: 12-20-2007, 09:43 PM
  4. Vehicle Security System Stickers??
    By ford01explorer in forum Car Audio
    Last Post: 06-08-2007, 02:51 PM
