Page 2 of 17 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 162
Thread: CarMa 2011 (public beta) [updated 14-04-2011] *old thread*
  1. #11
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Couldn't get it to do much of anything other then switch screens but the graphical work is incredible!! The interface reminds me of something from XBMC.
    Edit:
    Not having winamp installed might explain why I couldn't get music to play. Its a shame you guys went that route...a built in media player would have been pretty cool.
  2. #12
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Zoetermeer, Netherlands
    Hmm, sounds also like the above mentioned problem.
    CM tries to retrieve the installation-path of Winamp 2.9x from the registry.
    If it finds it, it will launch the winamp.exe (and shuts it down after closing CM)
    But if it can't find or launch Winamp, the playlist will always be empty.
    Thats because CM's playlist is actually the Winamp playlist.
    No winamp = No playlist data for CM.
    I'll think of something to solve this... An automatic search doesn't work
    for everyone, it seems.
  3. #13
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Quote Originally Posted by justchat_1 View Post
    Edit:
    It is planned, maybe I will go for it sooner. It depends on the requests I guess. (first one counted )
    It's just the matter of implementing 3 interfaces (player, eq and playlist) and FMOD, BASS
    or DirectMedia are within reach..
    I think it would be about 10hrs to implement a plugin for one of each mentioned player.
  4. #14
    Nov 2007
    Quote Originally Posted by jsn View Post
    Because CM uses the playlist of Winamp to record those actions,
    I think it probably couldn't, or didn't launch, Winamp.. Can you confirm that?
    Yes, I can confirm that. I don't even have Winamp installed.
    I'll fix that and try again.
  5. #15
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Sorry to bother you guys with 'another' install..
    Luckily it's a very known and lightweight player. But still...
    I'll give developing an integrated audioplayer a higher priority,
    but currently some other things and features will be implemented.
  6. #16
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    I've completed a new, and probably significant, build.
    It contains optimizations and a different notification system to update the layers.
    Some layers had their own update thread. I've replaced it with a different event system.
    It solved winamp sound glitches, which might be encountered on slower (<1ghz) machines.
    (due to excessive reading of the equalizer and volume data f.i.)
    The script execution became more responsive too.
    All good stuff..
    It's worth it to replace the previous version with this build.
    Enjoy!
    (use the link above to download,
    version of the exe should be 3.0.0.611)
  7. #17
    Nov 2007
    No worries.
  8. #18
    Jan 2010
    i must say, this looks very promising. i went back and read most of the older posts, and i like that you've stayed commited to this for such a period of time. i'm in the proccess of pricing out a carpc for myself, so ill probably try throwing this on first to see all your hard work.
  9. #19
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Quote Originally Posted by gaoes View Post
    Thanks and yeah, it is a long running project meanwhile, but I promised that the project
    will not be abandoned . The only difference now is, we're letting everyone follow the
    progress.
    Currently, we're very very happy with the framework, but it needed 3 rebuilds/redesigns
    of CM and almost 1.5yrs practice to get to this point. (admitted, there were some periods
    with less, or none, activity.. but still, much has been learned from the other implementations.. )
    Go check it out when you have your CarPC, and share your experience!
  10. #20
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Thumbs up
    I created a twitter account to keep you updated on the development.
    (subscribe here http://twitter.com/ProjectCarMa )
    An easy way to keep track of all changes and fixes!
  1. upgraded to 2/1/2011 and...
    By tundra2000 in forum Road Runner
    Last Post: 02-17-2011, 04:08 PM
  2. iDrive style skin || updated 24.01.2011
    By Konrad in forum RR Skins No Longer Supported
    Last Post: 02-02-2011, 12:32 PM
  3. Ces 2011???
    By Sonicxtacy02 in forum MP3Car Gatherings
    Last Post: 01-19-2011, 08:08 AM
  4. Replies: 280
    Last Post: 08-23-2008, 05:22 PM
