Page 3 of 17 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 162
Thread: CarMa 2011 (public beta) [updated 14-04-2011] *old thread*
  1. #21
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Zoetermeer, Netherlands
    Quote Originally Posted by gaoes View Post
    i must say, this looks very promising. i went back and read most of the older posts, and i like that you've stayed commited to this for such a period of time. i'm in the proccess of pricing out a carpc for myself, so ill probably try throwing this on first to see all your hard work.
    Welcome to the forum, btw
  2. #22
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Sounds cool, I'll try!
  3. #23
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    I've set up a temporary website with the downloads and some information.
    I'll update the FAQs when issues arise.
    You can check it out here
    Also, I hope to release a new build today with GPS support (with full script support).
    But let me know what you think is important to focus on next. There are still a couple
    of things to do, but thinking a bit ahead doesn't hurt..
  4. #24
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Plugins.
    Suggestion
    Let the plugins have their own subfolder in the plugins folder, just like the skins do.
    Question
    Do you have a example plugin structure code etc yet?
  5. #25
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Quite a good suggestion.. They might need their own support files or whatever.
    And it's already done now. I just had to set the 'recursive folder search'-bit, which
    was already supported in a custom filefind function.
    And yes, there are already examples.. I have an empty skeleton and I could offer the
    Audio-plugin (which is almost a full implementation of the Winamp functions).
    It is Delphi 2009-code, and should be compatible with earlier versions back to Delphi 7.0.
    There are no components, and everything is a self-contained package..
    As I learned, interfaces aren't Delphi specific, but are shared among modern programming languages.
    It should therefor be relatively easy to port it to a different language like CBuilder, C, C++, VC, etc.
    But I'm not sure about VB.. I don't know if interfaces are supported on this platform.
    Maybe someone can put a comment on that?
    If you want, I can send you a small SDK and the skeleton-plugin and for
    a full example the audio-plugin (implements the audioplayer, mediainfo, events and playlist).
  6. #26
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I'd like to take a look at any plugin SDK you may have.
    I use VB, but there is online converters from to C#.
    Be interesting to see if I can port my plugins to another FE.
  7. #27
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Sure!
    I'll prepare the package tomorrow.
    Unfortunately, I too, need some sleep
    The package will probably contain some documentation,
    the definition of the interfaces (which you might need, if you want to build something),
    and at least the skeleton plugin as example.
    The interfaces are set up really easy, they allow a plugin to control the application,
    and not just provide data with returning functions.
    They can also query if a certain (say GPS) plugin is loaded, and read the GPS data, f.i.
    Really flexible, it should give some creative ideas for plugin developers, I think...
    A scheduler plugin which controls the indoor lighting-plugin or whatever crazy minds will think about ..
    Also, keep an eye on the twitter list, it's going to be filled with every detail about the progression, updates and fixes!
  8. #28
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    I almost have the SDK/sample plugin finished!
    Going to upload it in an hour or so...
    I tried to document a lot of stuff, but still, it's probably not nearly enough
  9. #29
  10. #30
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Ahwell, other people can look into it too now
    I had it almost finished anyway, it's just a part of the pie, but needed some small adjustments and some comments.
    At least the codebase is easier to maintain now
  1. upgraded to 2/1/2011 and...
    By tundra2000 in forum Road Runner
    Last Post: 02-17-2011, 05:08 PM
  2. iDrive style skin || updated 24.01.2011
    By Konrad in forum RR Skins No Longer Supported
    Last Post: 02-02-2011, 01:32 PM
  3. Ces 2011???
    By Sonicxtacy02 in forum MP3Car Gatherings
    Last Post: 01-19-2011, 09:08 AM
  4. Replies: 280
    Last Post: 08-23-2008, 06:22 PM
