Page 6 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 162
Thread: CarMa 2011 (public beta) [updated 14-04-2011] *old thread*
  1. #51
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Zoetermeer, Netherlands
    Quote Originally Posted by SFiorito View Post
    You should only really care about the interfaces you defined (e.g. the ITuner interface in my example above). You then need to CreateInstance an object that implements that interface (e.g. MySamplePlugins.SampleTuner). You shouldn't need to actually load the assemblies yourself, let COM interop handle that for you as I did in the Win32 example above:
    Code:
    HRESULT hresult = pTuner.CreateInstance("MySamplePlugins.SampleTuner");
    Yeah, and thats the reason I need some XML file to be around to tell the host which
    class to instantiate, because CM can't guess the name by itself.
    Ofcourse, the filename could be a hint about this information (namespace.class.dll)
  2. #52
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by jsn View Post
    With Centrafuse the namespace has to be the same name as the dll name.
    So, that would be the way to go I think.
  3. #53
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Ah, that explains.. And CF plugins use a fixed classname for the plugins?
    (Admitted, I still have to look through the SDK of it)
  4. #54
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Each Plugin has it's own classname, which the same as it's dll name.
    ie
    gas.dll would have a classname of gas
    Trafficcams.dll would have a classname of trafficcams
    etc.
    Oh also the folder name has to match the DLL name as well, I think, with CF, although this may not be necessary just makes it easier probably.
    Basically CF goes through the folders in the plugin folder, looks for the DLL matching the folder name and loads the plugin accordingly.
  5. #55
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Alright.. May I suggest a somewhat simpler loading mechanism?
    (plugins in their own folder is okay, not forced but optional.
    CM just searches through all of them)
    Why not just namespace.classname.dll, like MyPlugin.TunerClass.dll ?
    It eliminates the need for another folder, and the CoCreate-string is
    directly readable from the filename.
    I'll try if this works, maybe I get it running in a few minutes :P
    Everyone thanks for the help and suggestions!
  6. #56
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Almost got it running!
    CM needs a couple of minor adjustments.. Right now I'm wondering why I can't use
    the interface after a successful QueryInterface. The app terminates right after the
    first method. If I'm using late-binding, everything is okay?! Weird..
  7. #57
    Jan 2010
    well i just ordered my hard drive, so as soon as i find a suitable touchscreen, ill just hook it up to my home computer and wait for my mobo to come out lol.
    its been a whole three days with no new posts
  8. #58
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Yeah, but don't worry!
    I'm still very experimenting with the .NET plugin stuff..
    I have the framework a bit too much Delphi I think, not really language independant.
    I was trying to convert parts of the framework, but now I'm thinking to just add
    another entry for it, or a plugin which can do the translation.. I haven't solved it yet..
    Anyway. I'm still working on it, but since it's all internal plumbing code now,
    there's no new published build yet too.. I'll post some more tomorrow and maybe I'll just
    continue working on other parts, and try this .NET-plugin thing again next week or so...
    I'm determined to get it working, but I want some visible progression for you guys too :P
  9. #59
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    I've decided to roll-back the changes since the last stable version.
    It's not quite working out as I expected. I'm thinking of putting in a separate
    COM interface, instead of modifying the current Delphi-interface framework.
    So, I'm going to go continue on other, more visible, parts of the application.
    Expect an update somewhere the next few days!
  10. #60
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    btw; what are your ideas for plugins,
    I ask this so I can implement the hooks you need!
  1. upgraded to 2/1/2011 and...
    By tundra2000 in forum Road Runner
    Last Post: 02-17-2011, 04:08 PM
  2. iDrive style skin || updated 24.01.2011
    By Konrad in forum RR Skins No Longer Supported
    Last Post: 02-02-2011, 12:32 PM
  3. Ces 2011???
    By Sonicxtacy02 in forum MP3Car Gatherings
    Last Post: 01-19-2011, 08:08 AM
  4. Replies: 280
    Last Post: 08-23-2008, 05:22 PM
