Page 7 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 61 to 70 of 162
Thread: CarMa 2011 (public beta) [updated 14-04-2011] *old thread*
  1. #61
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    My three main plugins at the moment are FuelPrices, Traffic cameras and Fiel Synchronisation.
    Have a look in the RoadRunner and Centrafuse Pugin subforums for my threads on them.
  2. #62
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Zoetermeer, Netherlands
    Quote Originally Posted by Enforcer View Post
    By looking at your work, I need to do a few adjustments to the core and extend the
    scripting language a bit further to be able to read data from the plugin into a layer.
    Not too much work I think.. But I still need to have a look (with a technical eye) to the
    plugin structures of RR. Maybe there is a way to make them load in CM.
    Also, I need to figure out the best way to display those cams.. We're going to use some
    webcams built into the car too, but thats the next chapter of CM I guess.
    -- edit: forgotten part --
    Also, there's no navigation yet.. Will be, soon I think.. but there are some technical
    difficulties with some of the nav-apps (garmin f.i.) to be solved.. the most generic
    would be to start the app and position it above the CM-window or something...
    But that's for later...
  3. #63
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    RR & CF plugins work in different ways.
    RR's dll basic has set routines which RR will check whenever something is needed for a particular skin, or a command is issued.
    The main ones being
    Buttons (or commands) which the plugin receieves and if it belongs to that plugin in acts on it.
    Labels which again if it belongs to the plugin is updated by the text sent back by the plugin
    Indicators, these can be on/off or a path to an image file.
    Indicators can also be clicked so act a bit like buttons.
    Whereas CF
    is more form based, it inherits certain things from CF, but also has a command return or request for info, but this has to be called directly by another plugin, although with CF3 it can also be called by a skin command
    I probably haven't explained it well.
    The camera images are static images not webbrowser windows.
  4. #64
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Well enough! I understand both ways, not the technical details of both products, but at least the concepts.
    My question to you, which way do you prefer?
    I can define a small amount of exports for you to implement in a DLL,
    or the more ActiveX/.NET/COM way? (they won't be exactly like CF or RR, but
    at least I can try to make it an easy job to port your plugins)
  5. #65
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It doesn't really matter to me.
    It's more which fits in best with the way your frontend works.
    Basic requirements are:
    Buttons/Commands, Labels, Indicators (although this is basically buttons with images), Buttons with labels.
    And a way of sending commands back to control the frontend. Fuel prices only needs to communicate with the navigation engine which you don't have at present but other plugins may need to control the Frontend, eg iBus for Steering Wheel control etc.
    Also an ability to have GPS coords routed through the frontend as well would be good, whether you have a navigation engine or not.
  6. #66
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Alright, I'll keep those things in mind.
    Most important is the callback system.. The framework already uses a kind of messaging system.
    Objects/layers/plugins/etc can subscribe to events. But this is all Delphi based interfaces.
    I need to think of a wrapper-plugin, which also implements some callback to 3rd party plugins.
    An event is based on enumerations and integers, so that's easy to transfer between the plugin and the host.
    But strings are a different story.. They work very different from VB, C#/++ or .NET
    based languages and are the cause of most serious headaches for developers
    (but maybe transfer via memory-mapped files or xml's are an option?
    need to investigate that later, unless someone has a great idea ofcourse )
    Right now, I'm finishing the Silabs USB FM Radio plugin. It's finished within a few hours.
    I'll start setting up a basic framework for loading other-than-delphi plugins after that.
  7. #67
    Feb 2010
    I think i have found my front end. I really like CarMa. But possible bug?
    Not displaying the artists first name on any tracks. Am running WinXP Pro. If you need any other info about my system let me know.
  8. #68
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    Quote Originally Posted by Linkin View Post
    Thanks!
    But that's an odd issue.. It reads the ID3 v2.x or v1.x data when a new mp3 file starts .
    Could you check if Winamp displays the same amount of data (ctrl-I in Winamp)?
    It should, if not, it's probably loading the wrong data from the mp3 and I need to fix that
  9. #69
    jsn
    jsn is offline
    jsn's Avatar
    Jun 2008
    I've released a new build including support for the Silabs USB FM radio.
    Don't mind the skin too much please, it is still very beta
  10. #70
    Feb 2010
    Hmm winamp displays the information properly. By the way this happens on every track I play. If the artist does not have 2 words or more it just displays a - and then the track name.
  1. upgraded to 2/1/2011 and...
    By tundra2000 in forum Road Runner
    Last Post: 02-17-2011, 05:08 PM
  2. iDrive style skin || updated 24.01.2011
    By Konrad in forum RR Skins No Longer Supported
    Last Post: 02-02-2011, 01:32 PM
  3. Ces 2011???
    By Sonicxtacy02 in forum MP3Car Gatherings
    Last Post: 01-19-2011, 09:08 AM
  4. Replies: 280
    Last Post: 08-23-2008, 06:22 PM
