Results 1 to 10 of 12
Thread: Redefine Keys?
    Dec 2004
    Question Redefine Keys?
    Is it possible to change what keys/commands are linked to a voice command??
    For instance, I'd like to change the "full screen" voice command to issue an F11, can I do this??
    I cans see how to add/launch new apps but not how to issue a new keystroke or edit an existing one.
    I'd like to customize Navivoice to work with the the two seperate navigation apps I use one for offroad use and one for onroad use.
    Thanks in advance.
    ..............Rikk
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Rikk
    Thanks in advance.
    ..............Rikk
    Rikk: you won't be able to have two navigation apps because you cannot have the same commands listed twice
    To change the full screen command: delete that command. Then add fullscreen to places and make the key be "VK_F11". That should do it. To focus on an app add its window class to the INI file under program_title.
    Why not track app focus and allow different command sets per app? Then you can re-use commands.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Arathranar
    You can re-use the commands on the app that has focus. Except for Frodo and Routis/iGudiance, those commands only work with those programs.
    Quote Originally Posted by 0l33l
    Then I don't understand what stops him using his different navigation apps.
    Jul 2004
    Berkeley, CA
    First: what navigation apps is he talking about? Well, iGuidance and Routis are basically the same. So I'm guessing Ninja Monkey's d3 and some of the aforementioned apps
    Currently, he would have to keep 2 INI files for the two apps.
    I thought that he would have two commands that are the same but are meant for different programs. That cannot happen because if the two commands are the same then SAPI will give an error
    Dec 2004
    One is Navigator 4, this is only temp as I intend to get Copilot 8 when it's released in the UK in a month or two.
    The other is called memorymap and is designed to display ordinance servey maps which I use for offroad driving of green lanes and byways.
    There are very few commands I actually need, these being.
    In Navigator
    Fullscreen - F11 (this is a toggle into and out of FS)
    GPS - To start the gps tracking
    In MM
    Zoom in - already covered by saying "plus"
    Zoom out - same, just use "dash"
    Lock - locks map to gps track
    Apart from focus switching and frodo control thats all I need, a man of simple needs
    Thanks for the above help I'll have a play tonight.
    Oh yes, I can't seem to find anything to tell me what the name of the app window is, saw mention of apispy but can only find one dload location and it's not on that site. Anything else I can use to find this info??
    Cheers
    ............Rikk
    Jul 2004
    Berkeley, CA
    In Navigator
    In MM
    Cheers
    ............Rikk
    As long as the programs take keyboard input you should be fine. For people like you, I've created MACROS. Read up on them in the HTML file. Basically you will need to delete the "full screen" command and put "fullscreen" somewere in the places. Then add macro to the places.
    As far as the focus: get a window spy. Then grab the CLASS and put that into the INI.
    Dec 2004
    I've been beating my head against a wall for an hour now trying to work out what to do and failing miserably.
    Could you just show me one step by step example of how I would change the fullscreen command to issue an F11 please.
    I think it's one of those things that once you've done once it's obvious, but trying to work it out to begin with sure isn't
    Thanks in advance.
    ............Rikk
    Jul 2004
    Berkeley, CA
    Thanks in advance.
    ............Rikk
    Add "VK_F11" for your places. Make sure to delete the old fullscreen command. Basically add fullscreen to your XML under the places, and remember the number. Then put VK_F11 into your places in the config program under the number that you still remember.
  1. Remapping WINAMP or WINDOWS keys
    By Roadrunner in forum Software & Software Development
    Last Post: 09-04-2005, 07:44 AM
  2. Global Hot Keys for Windows Media Player?
    By ejasons in forum FrodoPlayer
    Last Post: 11-26-2004, 08:45 AM
  3. Shuttle PN31 remote - programmable keys?
    By zaphodbb in forum Input Devices
    Last Post: 01-09-2004, 07:30 AM
  4. Default Winamp keys
    By jstiltner in forum LCD/Display
    Last Post: 07-16-2002, 11:21 PM
  5. mapping keys on logitech itouch KB
    By ShinkunoNamida in forum General Hardware Discussion
    Last Post: 06-02-2002, 02:56 PM
