Results 1 to 5 of 5
Thread: problems
    Constant Bitrate forevertheuni's Avatar
    Jul 2004
    Portugal,Mealhada
    problems
    Hi I followed the guides and I'm having this problem when python pycar.py .
    python pycar.py .
    Looking for translation file for language: ('pt_PT', 'iso-8859-15')
    Encodings found and used: ['ISO-8859-15', 'utf-8']
    Application pycar
    Background tasker started
    Module music imported
    Load module: music
    Removable /mnt/cdrom
    Removable /mnt/hda
    Error executing
    pymedia.removable.cd.init()
    rootDirs= val( 'params', 'audio_root' )
    rootDirs+= [ pymedia.removable.cd.CD(x).getName() for x in range( pymedia.removable.cd.getCount() ) ]
    root= menu.cache.setRoot( rootDirs )
    menu.cache.registerArea( val( 'areas', 'filelist' ) )
    menu.cache.registerArea( val( 'areas', 'iconlist' ) )
    audio.aFileList.init( self, root, pymedia.audio.acodec.extensions+ ['cdda'] )
    audio.aFileList.setRoot( root )
    audio.playLists.init( self )
    pos= audio.playLists.load( val( 'params', 'playlistDir' ) )
    audio.player.setInfoRenderer( val( 'areas', 'infoRenderer' ) )
    audio.player.start()
    audio.player.setPlayList( audio.playLists.getActive() )
    if pos!= -1:
    audio.player.startPlayback( pos )
    within ModuleHelper.execute
    !! Exception happened during creation or parse of app
    Traceback (most recent call last):
    File "pycar.py", line 246, in ?
    mainTest( s )
    File "pycar.py", line 148, in mainTest
    config.parse()
    File "/home/forevertheuni/Area51/pycar/pycar-1.2.3-pre2-src/pycar/parser.py", line 855, in parse
    self.parseNode( self.node[ 2 ] )
    File "/home/forevertheuni/Area51/pycar/pycar-1.2.3-pre2-src/pycar/parser.py", line 846, in parseNode
    app= self.processNodeByName( appNode )
    File "/home/forevertheuni/Area51/pycar/pycar-1.2.3-pre2-src/pycar/parser.py", line 101, in processNodeByName
    element.parse()
    File "/home/forevertheuni/Area51/pycar/pycar-1.2.3-pre2-src/pycar/parser.py", line 159, in parse
    target[ obj.id ]= obj.load()
    File "/home/forevertheuni/Area51/pycar/pycar-1.2.3-pre2-src/pycar/parser.py", line 809, in load
    NodeElement.load( self )
    File "/home/forevertheuni/Area51/pycar/pycar-1.2.3-pre2-src/pycar/parser.py", line 79, in load
    self.execute( 'onLoad', None, None, None )
    File "/home/forevertheuni/Area51/pycar/pycar-1.2.3-pre2-src/pycar/menu/generic.py", line 221, in execute
    exec( s1 )
    File "<string>", line 9, in ?
    AttributeError: 'module' object has no attribute 'extensions'
    Background tasker stopped
    forevertheuni@h5n1:~/Area51/pycar/pycar-1.2.3-pre2-src$
    In a world without Gates and Windows there are no fences or walls!!
    FLAC jbors's Avatar
    Nov 2003
    Try to grab latest versions from CVS (pymedia, pycar). There were some changes in pymedia 1.3.7
    Car pc integration with ease
    Car mediacenter
    Jul 2004
    Portugal,Mealhada
    how can I build it for linux?
    python setup.py build
    File "setup.py", line 2, in ?
    import py2exe
    ImportError: No module named py2exe
    Jul 2004
    Portugal,Mealhada
    this is from the pycar123.tgz package in the .iso
    python pycar.py .
    Application pycar
    Load module: music
    Removable
    Error executing
    useCD= val( 'params', 'useCD' )
    if useCD== 'enabled':
    audio.player.start( self.app )
    if pos!= -1:
    File "pycar.py", line 251, in ?
    mainTest( s )
    File "pycar.py", line 151, in mainTest
    config.parse()
    File "/home/forevertheuni/Area51/pycar/pycar/pycar/parser.py", line 861, in parse
    File "/home/forevertheuni/Area51/pycar/pycar/pycar/parser.py", line 852, in parseNode
    File "/home/forevertheuni/Area51/pycar/pycar/pycar/parser.py", line 99, in processNodeByName
    element.parse()
    File "/home/forevertheuni/Area51/pycar/pycar/pycar/parser.py", line 160, in parse
    File "/home/forevertheuni/Area51/pycar/pycar/pycar/parser.py", line 815, in load
    File "/home/forevertheuni/Area51/pycar/pycar/pycar/parser.py", line 77, in load
    File "/home/forevertheuni/Area51/pycar/pycar/pycar/menu/generic.py", line 220, in execute
    exec( s1 )
    File "<string>", line 11, in ?
    FLAC jbors's Avatar
    Nov 2003
    Let me post the latest distro. It is pretty much ready now.
    And also there is a tutorial available:
    http://indashpc.org/vbullettin/viewtopic.php?t=127
    Car mediacenter
  1. Still having XMPCR problems
    By rjoek in forum RR Bug Tracker
    Last Post: 09-23-2005, 02:08 PM
  2. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 08:12 PM
  3. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  4. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
