Results 11 to 20 of 24
Thread: AVG showing trojan virus in RoadRunner.exe
  1. #11
    Constant Bitrate avengerki's Avatar
    Mar 2006
    Oregon
    Wow I am having flashbacks from high school when I was writing a computer program and compiled it then wham anti-virus tells me I have a possible virus in the program I just wrote and just laugh and turn down the virus scan settings and all is good.
    Avengerki
    PC Install: 85%
    Car PC: Revo-Sys X300 Double Din: 1.3GHz Pentium
    Software install and setup: 35%
    Entertainment Package: 85%
  2. #12
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    Unless I'm totally missing a menu option I haven't seen any sort of exclude settings in AVG to have it completely ignore a file or directory. It looks like you can specify certain file extensions to scan, but it'd kind of defeat the purpose to take .exe off that list.....
    And when the error dialog box pops up the IGNORE option is apparently just a temporary/one-time thing.
    I may check out of AVAST's one, I've put AVG on all my computers and have had no problems with it at all, will never go back to Norton or one of the other big name bloated scanners.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
  3. #13
    Mar 2006
    Oregon
    In AVG if you go into the test center then select tests. then either the complete test settings or select area settings and uncheck the "use heuristic analysis" at least I believe this is the setting that may be causing the issue. At least its something to try if you are having this issue.
    Avengerki
    PC Install: 85%
  4. #14
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I checked the BETA version with AVG and it didn't say anything wrong about it.. maybe the last release coincidently had a sequence of data bytes in it that made AVG think it was something else.. feel free to download the latest beta if you're having trouble with it.
    Ride Runner RR's Myspace
  5. #15
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Im having trouble with latest version too
    AVG either deletes the file, or windows refuses to load it. I have disabled Heuristic searches, but I am not going to remove my AV program, is there a way round this yet?
    EDIT:
    Turned AVG off temporarily and now I get the windows permission error and file won't run, even when I re-download the file and try it new
    Has anyone tried contacting AVG to get an exception setup?
  6. #16
    Aug 2004
    On the edge!
    Bump!
    How are peeps getting round this?
  7. #17
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Download the BETA.
  8. #18
    Aug 2004
    On the edge!
    I thought I had
    the latest offering on your site Guino, where else would it be
  9. #19
    Dec 2005
    FL
    Like what has been mentioned in other posts the options are to either
    1) Download the beta
    2) Disable/uninstall AVG
    3) use a different virus scanner
    Nick
  10. #20
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by ShawJohn View Post
    I thought I had
    My site only has release versions.. check the last posts of the sticky release thread.
