Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 101
Thread: Silabs Radio Integration into Roadrunner
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    OK, just got this through the post and think its about time we all got together and got it put into roadrunner as from what I've read its a half decent radio and its much better than the dlink & radioshark..
    I havent downloaded any sources but it cant be that hard to put it into road runner, all the background work guino has done and I presume its just a case of joining stuff together..
    If you want to help .. have some source already in vb (RRMOBILE) that you want to help me put into rr then please post here..
    CdRsKuLL
    Feb 2004
    Manchester
    OK... UPDATE
    I have just been out for a drive in the car.. I have tested many radios.. including...
    Dlink
    Wintv+FM
    RadioShark
    HQCT
    and now the Silabs...
    whats the result.......
    Silabs ROCKS, its fantastic.. really is the best tuner I have tried.. this has to be integrated into RR.. TODAY !!!!!!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    link to where one of these can be pur chAsed?
    Feb 2004
    Manchester
    here u go m8.. I'm sure they will sell out fast..
    U know me m8, I have tried every bloody radio going.. and I am very impressed with this.. theres already a sdk around and some vb code that rrmobile has played with.. so it can defo be integrated in to RR.. it doesnt use a silly line in / mic in.. It doesnt use any drivers just plug and play..
    http://azzurri.stage.i-ntarsia.com/s...fmradio-rd.htm
    CdR
    Feb 2004
    Manchester
    ok here is the source for the radio control application they provide. Its in c++... I havent got a clue where to start with c++ . have also tried to load it into vs2005 but it errors on convert..
    source is at
    www.freedrive.co.uk/silabs.zip
    I think all you would need to do is make it hidden and then make it support roadrunner sdk commands so rr can control and talk to it.. cant be that hard
    CdR
    Feb 2004
    Manchester
    all you need to do is solder a car socket or whatever you want to call it in place of the little wire fly lead.. on splitting the case (just pulls apart) unsolder the wire aerial and solder the center of the car aerial in its place, right next to this is a bigger hole, solder the ground of the car aerial to this.. then snip the plastic bits that went through this hole from each side of the casing and zip tie it all together.. jobs done.. I've just been out again for a lttle drive.. just so I can listen to the radio.. how sad is that.. lol but ts been soooo long since Ive had a proper radio in the car of this quality.. it also has ts own volume slider and mute, so its easy to set the volume of it to tie into your system.
    CdR
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Someone made a USBRadio.DLL which seems fairly simple to integrate with RR. Shouldn't take much at all, the only problem is I don't have how to test it myself.
    Ride Runner RR's Myspace
    Feb 2004
    Manchester
    Hi m8, I will buy you one if you want and send it over... or I can do a remote desktop for you if you want access to a machine with one for testing.. let me know and I will get it sorted :-)
    CdR
    Feb 2004
    Manchester
    Hi m8.. just been looking about, and it seems someones already had a go at this.. attached is the dll and also a modradio from rr, but it was done before the radioshark integration so things just need to be moved about a bit. I will have a go myslef later, but since I'm already using your beta with FU and the available source is out of date.. blar blar.. :-) u know what I mean.. lol
    here are the files .. if you add the few lines of code and I will be able to test it.. I will still send u one.. as to be honest its the best thing I've tried :-)
    Steve
    Attached Files Attached Files
  1. HU Quality AM/FM RDS/RBDS Radio with Features
    By rando in forum Hardware Development
    Last Post: 12-04-2008, 01:11 PM
  2. RoadRunner uses, futures and configuration
    By marsk8er in forum Road Runner
    Last Post: 08-14-2006, 04:46 AM
  3. CarPC with stock radio integration
    By jnye6625 in forum Car Audio
    Last Post: 12-01-2005, 12:40 AM
  4. using my system as a radio as well can i do this
    By madkad in forum Road Runner
    Last Post: 08-20-2005, 04:18 PM
  5. FM radio Question
    By thepogcbr900rr in forum General Hardware Discussion
    Last Post: 05-09-2004, 07:27 PM
