Page 10 of 16 FirstFirst 12345678910111213141516 LastLast
Results 91 to 100 of 152
Thread: RR 04-11-07 .. GDI+, Silabs & More...
  1. #91
    Raw Wave
    Jun 2004
    On the beach
    The date above the links is wrong thats all. It is the 11th April 2007 release. I'm just not sure if another update was submitted after the initial release.
  2. #92
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Enforcer View Post
    Ok, let me just clarify, I can have different backgrounds for individual screens by changing the background variable in skin.ini on first load of that screen?
    However once a screen has been loaded up and a background assigned it cannot have the background changed unless a reloadskin is done.
    Correct?
    Thought, what if a screen is discarded can it not have a new background on next load (not that this is what I want to do but I thought I'd just ask)?
    You're 100% right on all of it. If it's discardable, you can reassign a background as every load of it is a "first" load.
    @ SAL R:
    I'll check the setpath stuff.. I know I "improved" it not to cause errors, but I thought I tried it fairly well here and it worked. What OS are you on ? maybe there's something to do with the removable drive structure messing my "folder detection".
    Ride Runner RR's Myspace
  3. #93
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by guino View Post
    Cool, sorts me out.
    Actually one more question, animated gif's YES/NO
    if YES also available as background?
  4. #94
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Used the 4-11-2007 revision on:
    XP Home Edition SP2 (Home Dev machine)
    XP Home Edition SP1 (carPC)
    Windows 2000 (Work Dev machine) <-Works flawlessly.
    Okay, played with it some more and it's definitely not working on any of my XP machines. Working fine w/ Windows 2000.
    It's reading all my available usb drives (External, thumb, Card readers, Lyra MP3player) just fine, but as soon as I move away from the default RR directory, I can't switch back to it unless I reload the skin/restart RR.
  5. #95
    Constant Bitrate GuMiSZu's Avatar
    Nov 2006
    Hungary
    Talking
    I changed the USBradio DLL and now it WORKS with
    ADS Instant Fm tuner!!!!
    THANKS FOR ALL
    guino if you want i send this dll and maybe you implement into RR
    radiomode 8 maybe
  6. #96
    Apr 2007
    great GuMiSZu ..i use this tuner too in RR .. at the moment only tuning works no RDS .. your DLL would inprove this so much .. i try your mc2.0 skin for the ADS but native support from RR is the best
    any chance to get this DLL ?
  7. #97
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by GuMiSZu View Post
    THANKS FOR ALL
    radiomode 8 maybe
    Theres a report on Digital Car that this unit is now also for sale in PC World over here ( UK ) for 39.99... might not be a bad addition if you cant get the Silabs or dont like it for some reason.....
    Terran
  8. #98
    Nov 2006
    Hungary
    Ok here it is dll for new RR and ADS Instant FM
    http://medit.uw.hu/USBRadio.dll
    could you test it? some response maybe
  9. #99
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    What did everyone do for an adapter back to the car. I desoldered the antenna, and added a female motorola to the truck. **Be careful** I ended up removing the solder pad from it. I'm working w/ the ADS FM...
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
  10. #100
    Jan 2003
    OK some imagineering for you lot ( and Gunio ) - Does evey one know about memory seats ? ( of course you do ). What about a simular thing for playlists so you / family can have your own stuff / exact play position just by pressing a button.
    For example if you have had the kids in ( oo ther half ) you may have some thing else to what you where listing too and in the case of kids ( and the weekend ) you may just leave it if just nipping to the shops for 5 mins.
    What about having a play list equiv to remember what each 'memory' has in its playlist and its track and postions - this way you can call it up very quickly and change in exactly the same way.
    I can add more around this later ( because this is the second but shorter time of typing it ) but does this sound of any intrest to any one ?
    Terran
    PS - I know about plays lists as such but what if like a number of others you don't just select the directory as such.
  1. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  2. RR + Mappoint 04 Not workin?
    By IntellaWorks in forum Road Runner
    Last Post: 07-13-2006, 11:19 AM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 09:15 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
