Page 6 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 51 to 60 of 152
Thread: RR 04-11-07 .. GDI+, Silabs & More...
  1. #51
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    Guino, I got some problems here that i don't know if they are related with the current release. Everything was working fine until this update. Config:via m10k, turtlebeach soundcard, 512ram, bu gps receiver. Now this has been running pretty slow but yesterday as you run road runner, the system goes to 100cpu usage and rr.exe is eating 80mb of ram. I tested this on another system and it was only 15mb. Also yesterday I plugged in the xm receiver and that didn't exactly work too well, so i took it off and changed the port to 0 in rrconfig. You have any ideas on whats going on here?
  2. #52
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Nice work guino!! small question:
    Did you fixed the problem with video and VIS reported by Cdr?
    Freedom Ultimate (Worklog)
    Thanks.
    Thanatos.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  3. #53
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by Sonicxtacy02 View Post
    i made changes to the weather stuff but it wasnt in the released source from yesterday. For poops and giggles try this beta out and see if ur weather works.
    http://www.sonicxtacy.com/roadrunner.rar
    anyone else having a weather issue?
    Hmmm...
    Still nothing...
    I just noticed also that I can't use the Web feature anymore either... which would explain the no update on Weather...
    Any ideas?
    Rafster
  4. #54
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    Quote Originally Posted by Rafster View Post
    Hmmm...
    Still nothing...
    Any ideas?
    Rafster
    clueless unfortunately... i dont think anythings been changed with the web code for some time.
    Live mp3Car Facebook Chat
  5. #55
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    can confirm the weather is working fine here, just checked. You must have the a problem with internet access with it for some reason.. what url does it pull that from ? just make sure you can access it from your internet browser.
    CdR
  6. #56
    Sep 2006
    I cannot find the added option to fade-in volume when starting up and resuming from hibernation. Can somebody point me in the right direction?
    05 Acura TL
    CarPC 99.99% Done
  7. #57
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by goosey2099 View Post
    I have not changed anything with XM support -- though I'll tell you that if XM is setup but not working properly, your system will run sluggish.. Are you running fastmode=0 or fastmode=-1 ? did you register the GDIPlus DLL ? I'd check for instance if you have changed something with any other settings that could be causing that. You may also need to update your Flash player -- that's typically a cause for High CPU load.
    Ride Runner RR's Myspace
  8. #58
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by KingofCorona View Post
    This is in the readme.txt.. just add: fadeinvolume=true in RR.INI
  9. #59
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Hmmm...
    Still nothing...
    Any ideas?
    Rafster
    Sounds like maybe you've changed some internet settings or disabled the network adapter ?? I do it all the time then keep wondering what's wrong.
    First question is: Does IE or Firefox work OUTSIDE RR? Do you have any proxy settings in there? Then go from there.
  10. #60
    Sep 2006
    Quote Originally Posted by guino View Post
    Thanks guino,
    I found it, added it and it works great
    05 Acura TL
    CarPC 99.99% Done
  1. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 08:04 PM
  2. RR + Mappoint 04 Not workin?
    By IntellaWorks in forum Road Runner
    Last Post: 07-13-2006, 10:19 AM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  4. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 08:15 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
