Page 7 of 16 FirstFirst 12345678910111213141516 LastLast
Results 61 to 70 of 152
Thread: RR 04-11-07 .. GDI+, Silabs & More...
  1. #61
  2. #62
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Quote Originally Posted by Enforcer View Post
    Quick question.
    Is it possible to change the background from screen to screen?
    Hello Mate,
    not Sure I understand what you mean, can't you use the skin header to do that ? menu_off.jpg etc ?
    I wrote an AutoIT script to change the Menu_off.jpg image in the Minimal skin. It copies from an image (either random or sequential) from a background directory and overwrites the menu_off.jpg image. I then had a button to allow you to change the background, but you needed to refresh the skin to make the change. Your welcome to use that (code below).
    NOTE This script hard codes the ini file it uses
    #Include <File.au3>
    #Include <Array.au3>
    ;Read vars from Minimal.ini
    $SkinPath = _PathFull(@ScriptDir & "..\")
    $SkinIni = $SkinPath & "Minimal.ini"
    $BGPath = $SkinPath & "Backgrounds"
    $BG = IniRead($SkinIni, "Minimal Skin", "MinLastBG", "File Not Found")
    $Debug = IniRead($SkinIni, "Minimal Skin", "MinDebug", "File Not Found")
    ; check for random background
    $setBG = IniRead($SkinIni, "Minimal Skin", "MinBGrandom", "NotFound")
    ; Get list of files into an array
    $BGList=_FileListToArray($BGPath,"*.*",1)
    ; if Debug is on, put the files in the background directory into a sorted list
    if $Debug >0 then _ArrayDisplay($BGList,"$BGList")
    _ArraySort( $BGList,0,1)
    If (Not IsArray($BGList)) and (@Error=1) Then
    MsgBox (0,"","No Files\Folders Found.")
    Exit
    EndIf
    ; select new BG seq or random dependant on setting in ini
    if $setBG = 1 then $BG=random(1,$BGList[0],1)
    if $setBG = 0 then $BG=$BG+1
    if $BG>$BGList[0] then $BG=1
    ; Prepare & write the file, and update Minimal.ini
    $FS = $BGPath & "\" & $BGList[$BG]
    $success = FileCopy($FS, $SkinPath & "\Menu.jpg",1)
    IniWrite($SkinIni, "Minimal Skin", "MinLastBG", $BG)
    ; If debug is on dump data for error checking
    if $Debug > 0 then MsgBox(4096, "Result", "SetBG="&$setBG & @CRLF & "BG="&$BG & @CRLF & $BGList[$BG] & @crlf & $FS & @crlf & $success)
    if $Debug > 0 then _ArrayDisplay($BGList,"$BGList")
    and heres the ini file
    [Minimal Skin]
    ; 0 = Off 1 = On
    MinDebug=0
    ; 0 = Sequential 1 = Random
    MinBGrandom=1
    ; last background used
    MinLastBG=1
    I have the script in a directory off the skin dir, the ini file is in the skin dir itself.
    Hope this helps.
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
  3. #63
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quick question.
    Do you mean this?
    "AUIDO","SETVAR;BACKGROUND;PIC1.JPG||LOAD;Audio_Pl ayer.skin"
    "XM","SETVAR;BACKGROUND;PIC2.JPG||LOAD;XM.skin "
    2001 S10 ZR2
    Chucks Skin - to old
  4. #64
    Maximum Bitrate Dalailama's Avatar
    Jan 2006
    Novara Italy
    Bugs or strange behaviour?
    Hi Guino,
    I'm playing with your new update and it works very well,I uploaded a patch for my skin to let others test it too .
    I saw some strange behaviour, they can't be called bugs I think... At the start appear the loading skin showing the loading status.
    It shows:
    - something about mixer I think... too fast to see :P
    -Starting Winamp
    -AUDIO ADV
    -NAVIGATION
    -LIBRARY
    -AUDIO ADV
    -NAVIGATION
    -LIBRARY
    The fact that catched my eyes was that all except the first are written in CAPITAL LETTERS (I'm sorry, I know it's not a problem, but I was just checking my skin and I saw it :P) after this I saw that AUDIO ADV, NAVIGATION, LIBRARY repeat twice.. Is it normal? Is it redoundant?
    Another strange behaviour is in the menu.skin file:
    MEDIACAR Skin
    MEDIACAR MainMenu Skin
    menu2_off.png,menu2_off.png,menu_on.png,menu_down. png
    INC,colors.txt
    INC,topdisplay.skin
    INC,bottomvolume.skin
    INC,titlebutton0.txt
    INC,titlebutton1.txt
    INC,titlebutton2.txt
    INC,titlebutton3.txt
    INC,titlebutton4.txt
    INC,titlebutton5.txt
    with this code RR doesn't include titlebutton0.txt (it's just a one line file with a /DEFINE)
    but include titlebutton1.txt...
    ...I tryed with this code...just one blank line more...
    MEDIACAR Skin
    INC,colors.txt
    INC,topdisplay.skin
    and it works, tryed also with this code... changed order...
    MEDIACAR Skin
    INC,colors.txt
    INC,topdisplay.skin
    and it works too...
    The error is repeateable.
    Thank you for the good work.
    P.S.:Is there a possibility of removing the % char in the volume label?
    Live today like it is your last day, and behave as though you will live forever...
    my WEBSITE
    MapMonkey Dalai skin-preview-download ITA-email me for ENG
    Road Runner CrystalBlue skin-preview-beta release
  5. #65
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    The RoadRunner Updater has been updated.. lol. see HERE for more info. There is now only ONE version, for both normal and touchscreen monitor usage.
  6. #66
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Chuck View Post
    Do you mean this?
    Yeah, that's the sort of thing I wanted to do
    I was just asking whether it would actually change or does RoadRunner need a reload to change the background image?
    It was a 'whether it would work' not 'howto' question
    runs and hides.
  7. #67
    Mar 2007
    I used the updater now my silabs will not play in rr. What do I do?
    It shows that it is on but I get no signal bars, I confirmed that it still works outside of rr. Are there setting I need to change? it is defaulted to radiator, is that correct?
  8. #68
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Radiator is no more necessary. All you have to do is set radiomode=7 in your rr.ini
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
  9. #69
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Sonix and Rafster:
    I noticed a problem with the weather as well with your(Sonix's) beta. Just by dumb luck it stopped working when I put the GPS timer line in after I realized my weather Button wasn't showing the gps city name. I added the line to the rr.ini, reloaded RR and the weather was not working. I tried a couple of times, and didn't know what was wrong. I removed the line from the rr.ini, fired up RR the weather worked again. Not sure if it is related to the exact problem you guys are having, but definitely worth a mention.
    My Fiero Build Thread
  10. #70
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Is this caused by the new tranparent capability in RR? Is there a way to turn it off?
  1. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 08:04 PM
  2. RR + Mappoint 04 Not workin?
    By IntellaWorks in forum Road Runner
    Last Post: 07-13-2006, 10:19 AM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  4. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 08:15 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
