Page 9 of 16 FirstFirst 12345678910111213141516 LastLast
Results 81 to 90 of 152
Thread: RR 04-11-07 .. GDI+, Silabs & More...
  1. #81
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Enforcer View Post
    Quick question.
    Is it possible to change the background from screen to screen?
    yes.. use setvar to define the path of the background image RIGHT BEFORE loading it with the LOAD command... "SETVAR;BACKGROUND;C:\1.jpg||AUDIO" .. "SETVAR;BACKGROUND;C:\2.jpg||VIDEO" etc... of course the path could also be in some other variable set in skin.ini for instance.. "SETVAR;BACKGROUND;$AUDIOBACKGROUND$||AUDIO" then have it like "audiobackground=c:\2.jpg" in skin.ini. However, CHANGING a already loaded background on the fly would require the skin reload.
    Ride Runner RR's Myspace
  2. #82
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Guino, So what exactly does the new GDI+ stuff do for us? Is it just added picture formats like PNG and Tiff? Or are there other commands or ini settings that can be used with GDI+ stuff.
    Just making sure what i need to add to RRSkinEditor to keep up with you
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  3. #83
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by guino View Post
    Ok, let me just clarify, I can have different backgrounds for individual screens by changing the background variable in skin.ini on first load of that screen?
    However once a screen has been loaded up and a background assigned it cannot have the background changed unless a reloadskin is done.
    Correct?
    Thought, what if a screen is discarded can it not have a new background on next load (not that this is what I want to do but I thought I'd just ask)?
  4. #84
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Ummm...the latest version off RR won't change paths to a removeable media.
    Here's my button code:
    SETPATH;$flashdrivepath$
    skin.ini
    flashdrivepath=G:\
    and can be changed on-the-fly via SETVAR.
    The good news is that RR won't lock up if the flashdrive is not connected. Howver, even if connected, RR won't change directory paths.
    Is there anything additional I need to be doing to enable RR to recognize that the drive exists?
    Also, confirmed not working on my carPC and two of my test machines.
    Last version that it was working on: 2-6-2007
    Version where it stopped working: 3-26-2007
    Am I missing something?
  5. #85
    guino's Avatar
    Nov 2004
    Toronto, Canada
    download the very latest.. there was an issue with it, but only if it didn't have a "\" at the end of the path.. so your example above should still work .. :|
  6. #86
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    http://guino.home.insightbb.com/download.html seems to be down Gunio......
    Terran
  7. #87
    Dec 2006
    agreed was just going to download it but no page and the mirror doesnt look up to date
  8. #88
    Aug 2006
    Sun Diego
    Okay, DL'ed v4-11-2007.
    It changes to other drives now, but it doesn't switch back to the default directory. :/
    Code:
    SETPATH;$musicpath$
    The funny thing is that if I assign another button to the default directory, it doesn't want to go to that directory either.
    i.e.
    rr.ini
    musicpath=D:\Shared Music\
    SETPATH;$musicpath$
    skin.ini
    flashdrive=D:\Shared Music
    SETPATH;$flashdrive$
    Neither button will take me to the specified directory.
    But if I assign "flashdrive" like this:
    flashdrive=E:\Shared Music
    or
    flashdrive=E:\Shared Music\
    it will go to the specified directory.
    Doesn't work with the "\" or without "\" when at the end using the default directory.
    It won't even take to D:\
  9. #89
    Raw Wave
    Jun 2004
    On the beach
    As far as I know the mirror is up to date, unless Guino has done an update since the mirror was up dated to 11th April 2007 release.
    If Guino has done an update and someone has the updates, please send them me and I will update the mirror.
    Dec 2006
    hmm maybe the mirror has he wrong data then, i says april 11 2006 above the links!
  1. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  2. RR + Mappoint 04 Not workin?
    By IntellaWorks in forum Road Runner
    Last Post: 07-13-2006, 11:19 AM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 09:15 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
