Page 1 of 16 1234567891011 ... LastLast
Results 1 to 10 of 152
Thread: RR 04-11-07 .. GDI+, Silabs & More...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 04-11-07 .. GDI+, Silabs & More...
    In this version:
    -Added GDI+ mode with support for PNG/TIFF/ICO for skins and picture viewer
    -Added native support to Silabs Radio w/ RDS (Thanks to Wickerswammie, RRMobile & CdR)
    -Added support to change speedatt settings as variables
    -Added WebZoom commands for FireFox (for Web function built-in)
    -Added support to save/load custom skin settings on separate INI
    -Added support for custom commands for switching the XM device to PCR mode
    -Added support for switching scrollable labels by clicking them
    -Added support to format date and time on labels/vars
    -Added support to specify file types to display on SD definition
    -Added support to display extensions according to SD definition
    -Added SETTOPMOST command to control window positions
    -Added RELOADRR command
    -Added background image loading support for transparent screens (GDI+ only)
    -Added TALK command (same as SAY without any volume changes)
    -Added option to fade-in volume when starting up and resuming from hibernation
    -Improved SETVAR to accept ++ with the meaning of ||
    -Updated Car2PC plugin for newer adapters (Thanks to Clarkie)
    -Fixed Issue with strcomp (changed , to ; )
    -Fixed Issue with videoshuffle also shuffleing audio
    -Fixed Issue with XM/SIRIUS unmute after using SAY command on some machines (unconfirmed)
    -Fixed Issue when using SETPATH with invalid path/drives
    -Fixed Issue with menu not showing up with focus by default (keyboard handling issue)
    By Robby_BMW:
    * Added the ability to change the encoding used for the phonebooks by adding the line "phonebooksencoding=CODE (i.e. phonebookscoding=ISO 8859-1)" in rr.ini. If omitted is used the standard encoding (UTF-8). (Snek request)
    * Added support for contact's picture in more PhoCo screens ("phoco.skin", "contacts.skin", "contactdetails.skin", "calls.skin", "call_out.skin", "call_in.skin", "sms.skin", "smsindetails.skin" and "smsoutdetails.skin"). (Freakers request)
    Notes:
    -To Use GDI+ you must set fastmode=-1 in RR.INI and register the DLL like this:
    Code:
    regsvr32 GDIPluswrapper.dll
    -GDI+ uses MORE memory than Fastmode=0 (default), but it's faster and allows for using transparency.. I know for a fact some skinners are already working on skins using that feature. It also allows you to use one of the high-res weather images on www.kompassist.co.uk and allows you to view PNG and TIFF on the Picture viewer.
    -It took a lot of time for me to work on the GDI+ stuff, so sorry if I didn't get some requests/mods in place in this release.. please feel free to remind me of anything I forgot.
    -Check TXT files for details on new commands and settings.
    -I haven't updated RRConfig yet, so if you want to use the Silabs radio, open RR.INI and set radiomode=7
    -If you want to skin with Transparencies, there's an example of Transparencies HERE
    -The Updater will be able to update to this version, but currently it says "unsuccessful" though it DOES work. W3bmast3r will update the installshield and the updater as soon as he has a chance to do so.
    There's always more to come.. enjoy it for now,
    Thanks for the support and patience with this long overdue update..
    Guino.
    Ride Runner RR's Myspace
    Low Bitrate fire's Avatar
    Oct 2005
    Melbourne, Australia
    very nice work guino... loving RR
    Current Setup - (as per PC specs on the left)
    Future Setup - Commell LV-677, Dual Core2Duo 1.86ghz, 1gb ram, M2-ATX, Morex Mini-ITX case, Transflective screen
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Thanks again for another release..
    You DA Man....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Thanks Guino, Great work as always
    I'll update the full installer in the morning... for now, the updaters should work
    note... the updater may say the update was unsuccessful.. not sure why yet, but it does work, and the updates are successful. Just tried it myself. Looks like I'll have to work on the updater... but you all are good to go
    /edit: @ Guino, the updater pulls the binary from your site, but to make things simple (not having to download the archive, extract, figure out the version, etc... just to get the version) it pulls the new version date from a text file on my site... so one lil change and it's good to go (which it's done)...
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Another nice update. Great job guino.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Another great release! Thank You Guino
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Feb 2006
    I dont know what id do without road runner. Thank you again for another great release
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Great job Guino you just made my life fun. Could you pm me with some links you found handy for GDI+ programming? Maybe some sites or books you found that helped you the most with adding the new features. Thanks.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by skiman View Post
    1000% Agree!!
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    tja
    tja is offline
    Aug 2005
    sydney, australia
    beautiful.. love the GDI+!!!
    thankyou guino!
    2005 Nissan Xtrail
    DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
    worklog
  1. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 08:04 PM
  2. RR + Mappoint 04 Not workin?
    By IntellaWorks in forum Road Runner
    Last Post: 07-13-2006, 10:19 AM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  4. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 08:15 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
