Results 1 to 10 of 15
Thread: anyone been successful with SKIPTO in flash skins?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i'm tryin to use the skipto command in my new skin but it doesnt seem to do anything. The directory list stays in the same position even though commands like SETLIST work fine. Anyone have this working that can shed some light?
    Live mp3Car Facebook Chat
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    does it work in a non-flash skin for you ? (it worked here in my non-flash test) I think CDR uses it in flash. Try using SELDL or SELPL before the command (according to the list you'd like to control).
    Ride Runner RR's Myspace
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    On a similar note,is there anyway that switchbutton will ever work in flash,i understand it works off the listed buttons in the skin file of normal skins but there aren't any of those in a flash skin.
    Really need a solution for that.(i'm a flash noob which doesn't help)
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by guino View Post
    works perfectly in non-flash skins. I'll try running seldl first.
    EDIT: I tried using SELDL before and GETDL after.. doesnt make a difference.. i'll see if CDr might shed some light.
    Quote Originally Posted by Griff1 View Post
    this is actually very easy... you just create a variable in flash and change that variable based on the number of times a button is pressed.. you can do it like so:
    Code:
    onSelfEvent (press) {
        if(_root.fghswitch=="0"){
            fscommand("SKIPTO;F");
            _root.fghswitch="1";
        }else if(_root.fghswitch=="1"){
            fscommand("SKIPTO;G");
            _root.fghswitch="2";
        }else if(_root.fghswitch=="2"){
            fscommand("SKIPTO;H");
            _root.fghswitch="0";
        gotoAndStop(2);
    of course you would want to put _root.fghswitch=0 on your onLoad() event on the scene
    Nov 2005
    Midlands
    Thanks Sonic,
    Mate you give me too much credit,EASY?Lmao
    I just started playing with flash at the end of last week,thanks to CdR's help i managed to edit HIS work to create a customized main menu for Freedom (remember me asking you about this a bit back?)
    And after that i made this but it really needs switch buttons to nav a large library.
    Woodbridge, VA
    Blog Entries
    55
    Thanks Sonic,
    you need switch buttons to do what exactly? i mean are you gonna have buttons tied to letters withthe skipto command in use or do you mean change the existing buttons you have there? Tell me what ur trying to do exactly and i can get ya thru it
    Nov 2005
    Midlands
    Quote Originally Posted by Sonicxtacy02 View Post
    sorry mate i wasn't very clear,
    I was trying to add some ABC DEF type buttons but in addition to the ones you see there
    being a noob i tried this =
    on (press)
    myColor = new Color(abc);
    myColor.setRGB(parseInt(_root.col));
    gotoAndPlay("/butsound:2");
    on (releaseOutside, release)
    getURL("fscommand:SKIPTO;#||SWITCHBUTTON;1>>SKIPTO ;A||SWITCHBUTTON;1>>SKIPTO;B||SWITCHBUTTON;1", "");
    Not my code but no worky anyway.
    Cheers for the script,that helps me loads mate.
    Woodbridge, VA
    Blog Entries
    55
    on (press)
    so yea we're doing the exact same thing. the code i mentioned above replaces the need to use SWITCHBUTTON. My problem now is that thru my scripting normal navigational commands in rr dont have an effect on my directory list. I was gettin my playlist and dir list confused... my playlist works fine with the UP DOWN SKIPTO etc etc but the directory list doesnt respond to any of em. I'll find a way to get it working. But in the mean time just try the code i suggested.. may or may not work with your lists.... but if you can use the keyboard keys to navigate your list it should work.
    guino is there a label that specifies the number of items in the directory list? I see playlistcount but that doesnt work with directory lists. I'm thinking some sort of array loop will do the trick with my issue.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I could add that label. Currently, you'd have to find that out by splitting the folder list array.
    Woodbridge, VA
    Blog Entries
    55
    I'll attempt to do add something here but in all honesty the playlist/directory lists coding is greek to me lol
  1. Whats the secret of optimizing flash skins?
    By Sonicxtacy02 in forum RR Skins
    Last Post: 02-16-2007, 08:40 AM
  2. Flash 9 Patch for SWISH based skins
    By pcsofty in forum Road Runner
    Last Post: 09-18-2006, 03:23 AM
  3. Windows update disables flash skins?
    By Vik in forum Road Runner
    Last Post: 08-25-2006, 06:37 AM
  4. Latest Flash causing lots of Flash Skins to break
    By RS200Z in forum Road Runner
    Last Post: 07-02-2006, 05:37 PM
  5. Flash skins?
    By Cris in forum Software & Software Development
    Last Post: 02-06-2006, 08:11 PM
