Results 1 to 10 of 10
Thread: GPS Status indicator?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Question GPS Status indicator?
    Is there a way (With Road Runner code, and no external scripts) to show a GPS Status indicator? I am looking for a simple way to determine if there is a solid satellite lock. This means 3 or more satellites locked. I am looking for more than just the label that shows the satellites currently locked.
    I would like to use an indicator in conjunction with this, if there are 3 or more locked then the indicator is "on" if 2 or less then the indicator would be "off", that would be ideal. I could settle for an indicator just showing if GPS is available or not (1 or more sat's locked)
    Even better would be a by using a signal strength "slider", similar to the battery level meter, XM & Sirius satellite strength, Volume ect.
    I could easily do this with an AutoIt script polling RR, doing the logic, and sending back commands to rr to turn an indicator on and off, but thats just one more thing that would have to be running all the time in the tray, or at the very least yet another timer event to fire at a given interval.
    Any suggestions?
    My Fiero Build Thread
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Use the "HEADING" indicator
    it only comes on when you have a lock
    2001 S10 ZR2
    Chucks Skin - to old
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Thanks Chuck,
    Copied from From SkinCommands.txt:
    "HEADING" - Indicates the most aproximate heading and displays the propper image for it (N, NE, E, SE, S, SW, W, NW -- JPGs on the SKIN's folder)
    This is a bit different than the "normal" indicator with just on and off state. So just make an on image and save it 8 times with the different names? Or can you just put the indicator over a location, and it will display what is in the on skin image?
    Sep 2006
    Lancaster PA
    John,
    Please excuse me if you already knew this, I am NOT a RR developer at all.
    In Skin Commands, there is the following:
    "GPSSAT" - GPS Satellites used (this is 0 if GPS has no valid info) (Road Runner Only)
    Could you use this?
    Jeff
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    if need be i could easily add one with an on/off state.
    Live mp3Car Facebook Chat
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by jswalls110 View Post
    John,
    Could you use this?
    Jeff
    thats a label not an indicator
    Sep 2006
    Lancaster PA
    Right, but it does give an on/off indicator for his worst case scenerio of any lock at all regardless of number of satellites, correct?
    Jeff
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by JohnWPB View Post
    Thanks Chuck,
    You would have to do the 8 .jpg thing for the on and the off would be whatever’s on the skin.
    2001 S10 ZR2
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    ok do the photoshop part you like...give me the 2 jpg's and i will do it for you in flash.
    oups you said no external scripts
    Sep 2007
    LA
    so is there an easy way to add an on/off GPS signal indicator as described by the OP? I'm already using the heading indicator to display the heading.
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  2. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  3. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 02:40 AM
