Results 1 to 3 of 3
Thread: TV and WAVE volume setting
    Nov 2006
    I have a WinTV USB2 and I am using the builtin support.
    When I click TV (runs the TV) command, the volume level of the WAVE line in MIXER shows that is has been changed by some % of the WINAMP level.
    If the WINAMP level is below 50%, the WAVE volume goes to zero or close to it.
    If the WINAMP level is above 50%, The WAVE level goes to 100%.
    And on exit from TV, it remains there. In the case of it being lowered, it means that MUSIC is so soft that it can't be heard and has to be manually adjusted.
    Any thoughts?
    Regards,
    Jim
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Try this in your ExecTBL.ini file
    Code:
    "TV","!PRESET;TOTV;WINAMP||SETVOL;WINAMP;0||LOAD;TV.skin"
    "EXIT","PRESET;TOTV;WINAMP||NEWEXIT",TV.skin
    "NEWEXIT","EXIT"
    2001 S10 ZR2
    Chucks Skin - to old
    Nov 2006
    Chuck,
    BTW, nice truck!
    When I enter TV while XM is playing, XN=M play stops, TV shows but with no sound. Checking MIXER shows both WINAMP and WAVE set VERY low. If I go directly to the mixer (all my screens have MIXER), I can adjust the volume of WinAmp and Wave back to correct levels.
    When I leave TV (via EXIT) and was playing XM, XM play resumes. However, if I came into TV from MUSIC, there is no sound until I go to MIXER and adjust Wave, WinAmp is back where it should be.
    Regards,
    Jim
  1. Eliminating Ground Loop
    By norbie in forum Car Audio
    Last Post: 08-11-2006, 01:56 AM
  2. Winamp tv plug in changes wave volume ?
    By CdRsKuLL in forum Road Runner
    Last Post: 08-02-2005, 07:46 PM
