Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Silabs and ADS compatible USBRadio.dll ...
    Constant Bitrate GuMiSZu's Avatar
    Nov 2006
    Hungary
    Cool Silabs and ADS compatible USBRadio.dll ...
    Hi!
    Here is an version that can use ADS instantFM and Silabs FM too.
    It detects the tuner no setup needed.
    Can anybody try it with Silabs FM tuner?
    It works with my ADS tuner but i can't try with Silabs.
    (Thanks For Steffen for HELP)
    This is an 2 in 1 dll
    Attached Files Attached Files
    Englishlessness :(
    Nov 2004
    St Louis
    Quote Originally Posted by GuMiSZu View Post
    Hi!
    Works good. Still need an RDS filter or something, but tune+/-, freq+/-, alternate station, coverage, signal, PS, PTY, Date and Time, etc working fine.
    Nov 2006
    Hungary
    Quote Originally Posted by GizmoQ View Post
    RDS filter or something: What do you mean?
    what is rds filter?
    maybe i try to make it...
    Englishlessness :(
    Feb 2007
    Johnston, RI
    I have a silabs radio..... the dll works with it ... however the RDS information is still having problems.... there are stray characters in the text....example....lite$rok@ at 105K.... which is mostly correct.... you are doing a great job.... if this last problem can be worked out this will be a great addtion to rr..
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    While your looking.... does this version support auto tuning to the strongest signal ? I know CDR was going to have a look but if your programing at the mo....
    I think the radio text thing was giving duff chars as well as the RDS info.
    Terran
    PS TA TP EON next please [begmodeon]
    Sep 2005
    Aylesbury, UK
    is there an overview of the functions/procedures in this? so the dll can be used for other frontends to implement the silabs radio?
    Sep 2003
    Quote Originally Posted by mischka76 View Post
    Yes this would be very nice or is there any way to get the actual source?!
    I'll take a look into the rr source for implementing the dll into a meedio-plugin but such an overview would be fine.
    NICE WORK!!!
    Sep 2003
    After some testing with C# importing the dll i am getting strange return values after ScanStation/SeekStation :-(
    return - key - station
    5330123133904036 - 040 - 91.3MHz
    5330123133906636 - 066 - 93.9MHz
    5330123133915636 - 156 - 102.9MHz
    5330123133919636 - 196 - 106.9MHz
    so i reason this long for 104.4 and YES it works:
    5330123133917136 - 171 - 104.4MHz
    After initialisation the dll returns for example
    5329384399531724 which seems to be the same like above-mentioned
    5330123133906636 because after next seekup the
    5330123133915636 follows and then after seekDown again the
    5330123133906636 is set and sounds same like this 5329384399531724!
    another conclusion after some calculation:
    5329384399540724 sould also be same like 5330123133915636 ?!?! -> tried: yes it is... hmm...
    But what do these longs mean, because i also can tune for example to 91300 getting every time such a representative long value as "GetCurrentStation()"
    It would be more useful getting the right frequencies
    Any ideas?
    I also found out that this dll returns only "" for GetRDS() :-( Is there anyone who gets RDS-Data with ADS?!
    Nov 2005
    subscribed
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    Quote Originally Posted by Fla**** View Post
    i have an ads tuner and the rds data is coming in, there is some problems with the data not showing right.
  1. ADS InstantFM integrated to RR
    By GuMiSZu in forum Road Runner
    Last Post: 06-06-2010, 04:28 PM
