Results 1 to 7 of 7
Thread: Autoswitch to a screen after X seconds?
    Jan 2007
    Greece
    Hi all!
    Is there a way to make RR autoswitch to a specific screen, if i don't touch the screen for some seconds?
    Like a screen saver.
    I want to make it to automaticaly taking me to a screen with only a big clock.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Idle command
    Yes, this is pretty easy to do.
    First, open the root Road Runner folder. Look for a file named exectbl.ini, and open it in a text editor. On a line by itself in that file put the following line:
    Code:
    "IDLE","Load;Menu.skin"
    That set's up what you want to happen when the system is idle, in this case, it will return to the menu screen.
    Next you will need to open each .skin file that you want this to happen on and put the following line in it:
    Code:
    IDL,30
    This is the amount of time, 30 seconds in this example, on that skin that RR will wait until it executes the command you put in the exectbl.ini file.
    This will need to be put in every skin that you want this to happen with. If there are some screens that you do not want to automatically leave, just do not put the IDL,30 in that skin file.
    My Fiero Build Thread
    Jan 2007
    Greece
    Great! It works fine!
    Thank you very much JohnWPB
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    or you can use a TIMER command
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Nomader View Post
    a timer command will fire at the given time no matter what. You could be in the middle of browsing your music, and it would take you away without warning
    Jan 2007
    Greece
    Correct. The point here is to launch the screensaver after some seconds of inactivity.
    Apr 2006
    Greece
    Quote Originally Posted by JohnWPB View Post
    yeah you are right..me wrong
  1. Replies: 14
    Last Post: 09-11-2008, 04:14 PM
  2. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  3. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 11:56 AM
  4. Cracked Touch Screen!
    By bmather9 in forum LCD/Display
    Last Post: 04-17-2007, 05:31 AM
  5. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
