Results 1 to 10 of 15
Thread: How to make two state buttons?
    Jan 2007
    Greece
    OK, here is another quick question.
    I want to make a button to have two states. A normal and a pressed one.
    When I press it, i want to stay in the pressed state, and when pressed again to return to normal state.
    I want to make sth like a switch. ON and OFF.
    I read the readme but i found nothing.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Try using a custom indicator for the button.
    Jan 2007
    Greece
    Any help on that?
    How i assing I01 to B01?
    The readme doesn't give any help...
    Aug 2006
    Sun Diego
    Use a similar format:
    Ixx,xxx,....,"!MYINDICATOR"
    for the button you want to change the state of (OFF/ON).
    When you push the button, on top of doing your command, you'll need to add a BYVAR argument (0/1). This, in turn, will set the state of the button using the following:
    "SETIND;!MYINDICATOR;OFF/ON"
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    got some problems trying this
    when I place a indicator over a button, when I mouse over it or navigate with the keys (the same effect as mouse over), the indicator desapears
    made some tests and indicators still there. if I place half the indicator's image over the button, just the overlayed portion of indicator is erased. the other half keeps showing nice.
    indicators are clickable itself, but it's not possible to navigate them just like buttons (guino please include this in next release... if its interactive, it should be n possible to access by keys )
    I just wanna a button that keeps highlighted till I press it again (toogle or state button like repeat or mute). but neither normal or custom indicators work when placed over a button
    help please, RR gurus
    []s
    Aug 2006
    Sun Diego
    Quote Originally Posted by will_santana View Post
    []s
    I've had the same problem with this. Static "ON" states disappears when you mouse over a button that has an indicator on it.
    You could work around it with the indicator blinking.
    Mar 2007
    thanks for the reply. i've already tried with blinking indicators, but some got REALLY annoying... imagine the repeat indicator blinking all the time the carputer is on...
    hope someone have some solution to this...
    []s
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Switchbutton command
    You can use the Switchbutton command to do this as well
    Code:
    "YourOnCommand||SWITCHBUTTON;1>>YourOffCommand"
    This will toggle the first command when you press it, and the second command when pressed, and when pressed again goes back to the first command.
    NOTE: This is dependant on where the button is in the .skin file. Meaning, in the above example, the button needs to be the "1" (first) button listed from top to bottom in the skin file.
    You can use the Double Pipe's (||) to add more than one command, such as:
    Code:
     "YourOnCommand||SETIND;!MYINDICATOR;ON ||SWITCHBUTTON;1>>YourOffCommand|||SETIND;!MYINDICATOR;OFF"
    I have not tested the above line, so syntax may not be perfect, but it should work.
    My Fiero Build Thread
    Aug 2006
    Sun Diego
    Code:
     "YourOnCommand||SETIND;!MYINDICATOR;ON ||SWITCHBUTTON;1>>YourOffCommand||SETIND;!MYINDICATOR;OFF||SWITCHBUTTON;1"
    Needs additional code to complete switching back and forth.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Sal R. View Post
    Code:
    Hehehe thanks, it's hard to remember some of the stuff when doing it from memory, If I would have taken the time to test it, could have noticed that right away
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. add buttons to home page
    By badassfirebird in forum Road Runner
    Last Post: 01-25-2007, 11:50 AM
  3. Brushed Skin Needs Some Editing (Bigger Buttons)
    By Chita79 in forum Road Runner
    Last Post: 02-20-2005, 08:37 PM
  4. Best way to make a 'flip up' monitor?
    By GReeToZ in forum Fabrication
    Last Post: 01-21-2005, 06:48 PM
  5. What's the difference between Hibernate and Standby?
    By BriCubz in forum General MP3Car Discussion
    Last Post: 08-17-2004, 10:32 PM
