Results 1 to 10 of 14
Thread: Connect GPS port at resume ?
    Hi,
    I just noticed that the bluetooth port is disconected when hibernating, and when resuming, it is not reconected, so basicly I loose the GPS in RR / MapPoint as soon as I hibernate (and I use hibernation all the time).
    So is there a way to connect the port again after resuming ?
    I use BlueSoleil.
    Greatful for help ..
    /E
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    HAve a search for a program called devcon (it may actually be included with the RR install) and it's usage.
    In fact this is a nice thread I found for you
    http://www.mp3car.com/vbulletin/faq-...de-devcon.html
    Thanks Enforcer,
    But actually I don't think that would help me.
    As I could understand, Devcon simulates a device reconection in Windows, and that is not really what I need.
    When resuming from Hibernation, the port in BlueSoleil is disconected, so I tried to reconect it, with RR and MapPopint still running in the background, and as soon as I reconected the port in BlueSoleil the GPS started working in MapPoint.
    So, it's not the BlueTooth device I need to "reconect", but the PORT in BlueSoleil.
    /E
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I don't have BlueSoleil installed on this machine, but I do remember setting something like this in the past. In the pulldown menu's, tools if I remember correctly, there is a auto connect to this device when in range type setting.
    My Fiero Build Thread
    Sorry, I can't find it.
    There is an option to automaticly connect when a windows program tries to open that port, THEN it connects as it should, and it connects as it should in BlueSoleil when RR starts. But when resuming from hibernation the port is disconected in BlueSoleil.
    So, is there a way to make RR open up the port again (and thus reconect it automaticly in BlueSoleil) when resuming from sleep ??
    /E
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yea, that was what I remembered... sorry....
    The only way I could think to do this is with a small VBscript that would open the port. This could then be run when RR starts. Looking at the AutoIt help file, I see no mention of opening com ports.
    This is just a thought, and not even sure if it would work to activate the link or not.
    Hmm, ok ..
    Wierd thing nobody has come across this problem before. It doesn't feel that uncommon.
    /E
    Jan 2007
    Brisbane
    no it happens to me also only way I have got around it is to have usb hub mounted in a ashtray and I have to pull out the bluetooth usb and reconnect it for BlueSoleil to read the gps device...prob not the best way to do it but I am no programmer just a simple hack.
    Newbie The6's Avatar
    Mar 2006
    UK
    Have a look for a tool called XPort 3 - I use it to wake up my GPS port after hibernate. Since I have been using it the GPS receiver has been up every time by the Sat Nav software after coming back from hibernate.
    You can also use this to give multiple programs access to the same COM port eg two sat nav programs access to one GPS receiver.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Eminos View Post
    Thanks Enforcer,
    /E
    I take it that you then never even attempted to try this and see if it in fact doesn't work for you?
    Quote Originally Posted by playz View Post
    Correct me if I'm wrong, but these are accomplishing the same exact thing, execpt that you wouldn't have to remove the dongle.
    I have used devcon in the past as a work around when I was using a PowerMate for my volume control. After returning from standby sometimes it wouldn't get reconized.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Can't tell SD not to open GPS COM port
    By rburhum in forum StreetDeck Bug Reports
    Last Post: 06-28-2007, 10:37 AM
  2. Replies: 7
    Last Post: 04-03-2007, 02:47 PM
  3. Opening virtual gps com port.
    By EricE in forum Software & Software Development
    Last Post: 03-19-2007, 01:51 PM
  4. Replies: 0
    Last Post: 02-26-2007, 06:18 AM
  5. Replies: 4
    Last Post: 08-05-2005, 04:43 PM
