I thought I found the right info using the search here but i'm still having problems.
Here is my configuration:
Here I want to use the letter L in 2 different skins. It just doesn't work.
What am I doing wrong?
Just figured it out myself.
I removed the 2 entries from the ExecTBL.ini and changed the 2 entries in the KeyTBL.ini to:
I still don't understand why that works.
I read here that the KeyTBL.ini is where I define the keys and in the ExecTBL.ini they are allocated to the skin.
Could someone explain a little better or create a FAQ that would explain more?
