Results 11 to 20 of 29
Thread: No sound with Silabls USB Radio...
  1. #11
    Jun 2005
    Dresden, Germany
    The same here.
    Radiomode set to 7 and no sound with RR. The LED in the Silabs radio ist flashing. With the Silabs software the LED is changing colours and I can hear radio.
  2. #12
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Glad I'm not alone lol... I've posted on the main Silabs thread as I belive I have found the problem but not a solution.... I'd be intrested to see if our setups have any thing in common.
    Terran
  3. #13
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by Iceman_jkh View Post
    Also, if you run RRconfig, it will reset Radiomode to 0. This is because according to the current RRconfig, there is no such mode as '7'. It sees this as an error and corrects it back to '0'. I'm sure Guino will rectify this in a future RR release, but just make sure to keep changing it back for the moment .
    Also, there are no drivers for the SiLabs unit. It auto-installs and appears as some kind of HID device, and downloads the audio via the USB cable, into your computer's windows audio (possibly wave) stream.
    I noticed that. So I just edit the .ini file and make sure radiomode=7.
    Still radiomode=7 at startup, during, and close of RR.
    I'm stumped.
  4. #14
    Nov 2005
    I dont think you can edit the .ini while RR is running. The change/problem only occurs when you use RRconfig.
    Regardless...
    Check out post #4 (http://www.mp3car.com/vbulletin/road...-rrconfig.html)
    Should solve the problem
  5. #15
    Aug 2006
    Sun Diego
    Regardless...
    I didn't edit the .ini while RR was running.
    I just made sure that prior to startup, radiomode=7.
    Set a label to show $radiomode$.
    Checked rr.ini after exiting to see if RR was changing this variable.
  6. #16
    Nov 2005
    There are also issues with the Radio being put into MUTE mode (I believe).
    I think (not 100%) that if you accidentally use RR (sets Radiomode=0) then run RR and open RADIO, it attempts to run Radiator. If you (like me) had previously tried USBradio.dll in Radiator, then those are the setting it will still be on. When it does this it crashes Radiator on my PC. If this happens (ie: Radiator running the USBRadio.dll), it wrecks the radio output, cause I think this is when it puts the radio into MUTE mode, and doesnt/wont bring it back out. I think this is why my radio (which did work fine for a while) has now gone silent. Because (and I'm sure of it) I have used RR (after RRconfig set RadioMode=0) and selected RADIO and I saw radiator come up, then crash, and now NO SOUND . So I'm pretty confident Radiator has set USBRadio.dll to mute and wont bring it out and thats the issue.
    Just a friendly warning!
    I'll report back if I figure out how to unmute it. And if that was indeed the cause of the problem.
  7. #17
    Aug 2006
    Sun Diego
    Interesting theory. If the radio wasn't working, it shouldn't be passing rds info. However, my skin is getting rds info as I'm typing this.
  8. #18
    Nov 2005
    I didnt say 'not working'... I said 'no sound' .. I think this is exactly whats happening. Its working, but the audio stream has been turned-off/killed/muted by something Radiator did.
  9. #19
    Nov 2005
    Got it working again!
    Close RR/RR config.
    Open Radiator.
    Open Settings.
    Go to Hardware tab.
    Select "Built-in (Radiator) Driver".
    Make sure Radiator is not on MUTE.
    Set radiator volume to full.
    Close radiator (Kill it via Taskmanager if necessary)
    Uninstall Radiator.
    Make sure all Radiator files\directory are deleted.
    Double check that the correct/latest USBRadio.dll is in your RR directory.
    Double check that rr.ini has RadioMode=7.
    Enjoy your USB radio!
  10. #20
    Aug 2006
    Sun Diego
    I've never had radiator installed...or any other radio program for that matter.
  1. usb sound getting winamp stuck
    By skywise in forum Road Runner
    Last Post: 06-12-2006, 02:42 PM
  2. Sound hooked up, having USB and popping issues
    By dbzeag in forum Car Audio
    Last Post: 05-28-2006, 02:38 AM
  3. Radio and Tv usb card
    By CdRsKuLL in forum Road Runner
    Last Post: 04-21-2005, 05:18 PM
  4. USB Sound blaster vs Audigy NX 2 USB
    By sivart321 in forum General Hardware Discussion
    Last Post: 04-07-2005, 04:06 PM
  5. Sound Quality with External USB Soundcard
    By nirvanades in forum General Hardware Discussion
    Last Post: 08-12-2004, 05:34 PM
