Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: No sound with Silabls USB Radio...
  1. #21
    Nov 2005
    Quote Originally Posted by Sal R. View Post
    Totally wierd. The silabs sound comes thru in my carPC, but not my dev machine.
    Oh well...
    So your CarPC machine works correctly?
    Much earlier you mentioned that you needed to copy the USBRadio.dll (+2 others) into the RoadRunner directory. Are you sure that you are running the latest version of RR on the Dev (current) machine? The latest RR comes with those files already in the RR directory. Perhaps you are running an old version and thats why it doesnt work?
  2. #22
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by Iceman_jkh View Post
    As far I know, they are the latest files from guino's site that includes the latest RR release (4-11-2007). I used the same .dlls in my carPC.
  3. #23
    Nov 2005
    If you can.. just make sure you only have 1 copy/version of RR installed. I had two versions.. 1 in Program files, the other on the desktop. I had so many shortcuts that I got confused, and in the end I had problems when things werent working properly, and I couldnt understand why. Delete all the copies if you can (or temporarily put them somewhere else) and try a fresh install of RR 11-4-07. It should work straight away (with only changing RadioMode=7).
  4. #24
    Feb 2006
    Hi all,
    I've got the same problem... can use the radio using Silabs' utility, but not in the latest version of RR (April 2007)
    Radiomode is definitely set to 7, and I have never had Radiator installed. This is a clean RR too, just installed.
    Any ideas?
    Thanks.
  5. #25
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Are you setting radiomode=7 manually in rr.ini? if so, it's been known to change back to 0. You need to have the RRconfig that has the option to select "silabs" from the drop down box.
  6. #26
    Feb 2006
    What is the difference between setting it manually and setting it in RRConfig??
  7. #27
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    NONE, unless you use the config which would have to be re-edited after your save your settings. The currently included RRconfig doesn't keep any setting that it doesn't understand this being one of them
    Check this post for an updated config that includes a silabs option.
    Radiomode resets to 0 if using RRconfig
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #28
    Feb 2006
    I understand that and I actually have this version.
    But from what treetop777 is saying, he seems to suggest that I need to change it in RRConfig instead of manually changing it? Of which I didn't think there was a difference?
  9. #29
    Sep 2006
    War-Town, GA.
    You're right, since you have the correct RRConfig, it don't matter where you change the setting.
  1. usb sound getting winamp stuck
    By skywise in forum Road Runner
    Last Post: 06-12-2006, 03:42 PM
  2. Sound hooked up, having USB and popping issues
    By dbzeag in forum Car Audio
    Last Post: 05-28-2006, 03:38 AM
  3. Radio and Tv usb card
    By CdRsKuLL in forum Road Runner
    Last Post: 04-21-2005, 06:18 PM
  4. USB Sound blaster vs Audigy NX 2 USB
    By sivart321 in forum General Hardware Discussion
    Last Post: 04-07-2005, 05:06 PM
  5. Sound Quality with External USB Soundcard
    By nirvanades in forum General Hardware Discussion
    Last Post: 08-12-2004, 06:34 PM
