Results 1 to 5 of 5
Thread: RoadRunner.exe Disappears
    Apr 2007
    Hi, this is my first post here. I'm trying to explore my way. I downloaded RR verion 7/10/2005. When I run the update everythin goes OK until the update is installed, then the RoadRunner.exe file disappears, i.e. it's not in the program folder. Any suggestions?
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by ahegazi View Post
    If you are having trouble with the self install, download the Roadrunner Binary at:- http://www.kompassist.co.uk/
    Unpack it to C:/Program Files/Roadrunner, and run RRConfig to insert your directory paths to Music, Video etc. Also don't forget to install Winamp, and if required your GPS application of choice.
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    Raw Wave
    Jun 2004
    On the beach
    Disable your antivirus as you update - some AVs delete the roadrunner.exe binary thinking it is a virus due to the compression software used when compiling, I believe this has been resolved with the latest version but I haven't upgraded yet so not 100% sure on that.
    Apr 2007
    Thank you both for the quick reponse.
    @Gobby, I have NOD32 and gives me warning of a virus, and I ignore it. However, maybe it still does smothing to the file. I'll see if I can disable the antivirus.
    @Wizz, Thanks for the hint and explanation. I'm goin to try it if diabling the AV does not help.
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    You'll see a similar (or the same) issue in the main installer updater thread here. Starting around post #99. Basically the "Advanced Huristics Detection" was killing/deleting RoadRunner.exe INSIDE the Zip Binary archive before even extracting or if using the Installer, as soon as it's installed it's deleted. If that's the case just disable Advanced Huristics Detection. One guy had the issues coming from NOD and ZoneAlarm's Security Suite, both at the same time.. lol Good Luck.
  1. AVG showing trojan virus in RoadRunner.exe
    By nkotch in forum Road Runner
    Last Post: 07-21-2008, 09:09 AM
  2. Roadrunner.exe dont work in Windows Vista
    By xpluis in forum RR Bug Tracker
    Last Post: 04-13-2007, 10:24 AM
  3. Replies: 4
    Last Post: 06-15-2006, 10:54 PM
  4. Replies: 17
    Last Post: 12-15-2005, 06:51 PM
