Results 1 to 5 of 5
Thread: iGuidance
    Apr 2007
    iGuidance
    For some reason, my IG loses my GPS settings every other time I start it. I have to go back and set it to Comm 16 manually, which is a real pain. Does anyone know of a way to force a comm port via command line when starting iguidance.exe?
    this happens both starting it from RR and from the normal iguidance icon on the desktop.
    Also, I'm linking to IG as "external" in RR, nothing special (I don't know enough to get IG actually set up properly in RR).
    Any ideas?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Wink
    iG does not like com ports over 9.
    I could have slapped you now with a search and rtfm but my hand is hurting already. Good luck.
    Apr 2007
    haha, thanks.
    I have a bunch of the lower comm ports taken by my bluetooth, but I guess I can rearrange them.
    Constant Bitrate cMags's Avatar
    Jun 2005
    Marietta, GA
    Well I, for one, appreciate you putting out that info - because a buddy of mine can't get his iG3.0 to keep a lock on his GPS on COM-11 so that explains things. I just happened across this thread and you unintentionally solved a problem for a buddy of mine. Thanks!
    CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
    Apr 2007
    Just tried it and it worked perfectly. Thanks!
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Hacking Iguidance
    By Peoples in forum GPS
    Last Post: 08-28-2005, 07:40 PM
  5. Replies: 2
    Last Post: 08-19-2005, 12:15 AM
