Results 1 to 5 of 5
Thread: Anyway to make Volume Logarithmic
    Jul 2006
    Is there anyway to make volume logarithmic instead of linear? Like how centrafuse allows you to choose between the two. I've tried tying the volume to all levels but it starts off funky everytime for some reason.
    On a side note, whenever i start my car but i don't touch the touchscreen for 15 minutes, it automatically hibernates. I have it set to hibernate after 5 hours, not 15 minutes. Also as soon as I touch a button in RR its back to normal and I can wait 4 hours and it wont auto hibernate. It's only a problem if you dont touch a button in the first 15 minutes. Anyone ever have the problem and have a solution? It's annoying when others borrow my car and it shuts down on them or when i'm talking to passengers and dont play with RR. I'm wondering if its either a function of RR or the touchscreen drivers.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    very odd with the hibernate issue, so if you disable hibernate will the computer then shutdown in 15min?
    Not a solution to the problem, but more of a temp work around, you could have a script that will click your mouse for you so it stops the shutdown so u dont have to manually do it.
    Such a script is attatched to this post.
    Stick it in your startup folder and it will run and wait for 5min then simulate a right click then exit.
    If chose the right click since RR will ignore it. This should tide u over till u figure out the real issue.
    oh and if you want logarithmic audio i believe winamp can do this. It will only work in winamp though.
    Options> Preferences> Plugins> Output> DirectSound output v2.42> "Other" tab> volume control
    Also some other nifty options in this window if you've never ventured into it.
    Attached Files Attached Files
    beer replenishment fund
    mp3car live search
    Nov 2005
    garto> I have a similar problem to your auto-hibernate.
    Mine stays alive for 5-10 then hibernates if I dont press anything. If I press anything at all, it will stay alive until I leave the car & the shutdown controller kicks in.
    I have an intel D865GLC motherboard and am using TinyXP 5. Anything similar to your setup? I think I have hibernate set to never. And Hibernate on power button press (for the shutdown controller).
    Jul 2006
    How do I tie master volume to winamp. In the configuration there looks to be no setting for that. Thanks so much liquid smoke for getting me that script, I think it will work perfectly.
    Dec 2006
    College Park MD USA
    Quote Originally Posted by liquid_smoke View Post
    oh and if you want logarithmic audio i believe winamp can do this. It will only work in winamp though. Options> Preferences> Plugins> Output> DirectSound output v2.42> "Other" tab> volume control
    Woohoo! Chalk another one up to this guy and the Search function. Thanks
    Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
  1. Replies: 56
    Last Post: 12-29-2005, 05:06 PM
  2. Winamp volume problems
    By froop in forum Road Runner
    Last Post: 09-17-2005, 11:02 AM
  3. Volume in girder
    By Maņana in forum FrodoPlayer
    Last Post: 03-27-2005, 07:19 AM
  4. Replies: 11
    Last Post: 02-11-2004, 10:59 AM
  5. Replies: 6
    Last Post: 11-12-2003, 09:57 PM
