Results 1 to 6 of 6
Thread: GPS skin related questions
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    I have S&T with RR. I use a customized CFX skin as my main, and the BMV2-esque GPS skin with all the nice S&T buttons. The problem is that when I switch to GPS, the S&T window ends up on top of the RR skin -- I have to exit back to main and then enter GPS again for it to look right. Is there a way to fix this so it looks right the first time?
    Also, I saw that RR includes a label that supposedly shows the number of satellites. However, it always shows "1". Does this really work? If so, what am I doing wrong? Is there a way to have an indicator that lights when I have a good GPS fix?
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    The S&T works fine. You didn't post which version you have, 2006 or 2007 or the gps skin file. Probably you're losing the focus when you call S&T. Set it up as the external GPS in the exectbl.ini file.
    For GPS indicators to work make sure you have a com splitter for the GPS receiver working. They have to be on a different com-port than your GPS program. Make sure to have indicators for your skin in you're using the North, south, etc directions..
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Also S & T changed the window title between 2006 & 2007 versions. One is spelled out, and one uses the ampersand symbol: "Streets and Trips" -vs- "Streets & Trips". If the window title is incorrect in the RRConfig then RR can not embed the window properly.
    My Fiero Build Thread
    Nov 2006
    Everett, WA
    I'm using S&T 2007, sorry for not mentioning that. I have it set up as external GPS in RR. I don't know what you mean by com splitter. Do you mean that RR has to be reading the GPS on a different COM port than S&T? I think I have it set so that it's putting out NMEA on 2 COM ports and RAW on another. S&T reads the NMEA on COM3. If I set it to COM1 it gets confused.
    I'll try the name change and see what happens.
    Constant Bitrate cMags's Avatar
    Jun 2005
    Marietta, GA
    The name change should help out with the focus issue. For RR and S&T to both read your GPS, you need to split the signal. So, right now you've got S&T reading your GPS on com-3. Search for "XPort 3" (by member Curiosity IIRC). Set it up to read com-3 and output to com-4 and com-5. Set RR to read one and S&T to read the other.
    CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
    Nov 2006
    Everett, WA
    Well the other RR GPS-related things work, like the speedometer and compass (on the flash clock), but even in those displays it says there are 0 (zero) satellites. Is gathering the number of satellites something else?
    I looked at my RR settings and the window name was correct: "Microsoft Streets & Trips"
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. Blue Devil Skin RELEASED
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 01-05-2007, 08:54 PM
  3. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  4. MCE 2.0 Skin question regarding GPS
    By niccard007 in forum Road Runner
    Last Post: 02-23-2006, 01:28 PM
